TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Oct 15, 2017 at 3:10 PM
    #4341
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do it.....do it
    jojotoo likes this.
  2. Oct 16, 2017 at 7:02 AM
    #4342
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I just looked it up and it sounds really good! Too bad my DTs headers aren't equal length and I've read the U-Spec headers don't fit trucks with the coil bucket gusset. I'll see what I can do to try and match the y-pipe lengths a bit.
  3. Oct 16, 2017 at 7:29 AM
    #4343
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    People have had them fit. I don't remember all of what the circumstances were. Some had said that the DTF or Bonzen engine mounts help prevent them from hitting.
  4. Oct 16, 2017 at 7:43 AM
    #4344
    ls1 prerunner
    Andy
    El Paso, TX
    I made my own solid mounts, so that may help. Anyone want to trade DT long tubes for URD U-Specs with cash on top on my side?
  5. Oct 16, 2017 at 8:55 AM
    #4345
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Try to make your y-pipe arms equal length from the collector.
    ls1 prerunner[QUOTED] likes this.
  6. Oct 17, 2017 at 5:18 AM
    #4346
    snozkc
    snozkc Member
    Ethan
    2010 Tacoma Supercharged 4x4 manual
    Has anyone out there found oil in the inter-cooler of their TRD supercharger? This is what I found while removing my supercharger for maintenance. The vehicle was running fine and has never smoked. I could tell that oil had been leaking out from under the inter-cooler cover and was getting past the intake gasket. Is there a PCV valve somewhere on these when they have a supercharger?
  7. Oct 17, 2017 at 5:58 AM
    #4347
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    gersus and ls1 prerunner like this.
  8. Oct 17, 2017 at 6:03 AM
    #4348
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Catch can helps, I still get oil in the intercooler.
    12TRDTacoma likes this.
  9. Oct 17, 2017 at 6:37 AM
    #4349
    snozkc
    snozkc Member
    Ethan
    Thanks for the info. I think I'm going to look into adding one.
  10. Oct 17, 2017 at 7:22 AM
    #4350
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Even with the catch can? How much? I was considering putting one on but if oil is still going to get in it kind of defeats the purpose :notsure:
  11. Oct 17, 2017 at 9:07 PM
    #4351
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Different catch cans will having differening levels of success. (Baffled, chambered, neither.) As well as hose size in and out of it.
    Murphinator likes this.
  12. Oct 18, 2017 at 7:23 AM
    #4352
    mightytacoman
    Kel
    4.5L 1grfe
    Tough to say how much. My catch can is the add one design and it catches a fair amount. There is always a thin layer of oil inside the intercooler. I notice I get oil out from the passenger side hose that connects just before the throttle body.
  13. Oct 18, 2017 at 7:37 AM
    #4353
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Interesting. I’ve read on here or xr underground that it’s best not to connect the passenger side hose to any catch cans. I suppose no matter how good the driverside can is, oil is going to get through. I think I will still get one just to help eliminate some of it.
  14. Oct 18, 2017 at 8:54 AM
    #4354
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Passenger side hose should be left alone, unless you have a turbo.
    inwood customs and Murphinator like this.
  15. Oct 20, 2017 at 5:59 PM
    #4355
    tacotime1
    tacotime1 Well-Known Member
    Rotor pack sounds like it’s got mashed up packing peanuts in it, like a flutter. This is with no oil in the nose cone makes the noise when the pulley is turned. Any ideas? The rotor pack does have some coating coming off, but not that loose!
  16. Oct 20, 2017 at 6:14 PM
    #4356
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Coupler or the bearings.......or both.....
  17. Oct 20, 2017 at 6:23 PM
    #4357
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Steigmeier or other place for a rebuild. Unless you can do it yourself.
    inwood customs likes this.
  18. Oct 20, 2017 at 6:25 PM
    #4358
    tacotime1
    New coupler, so the bearings in the rear of the Supercharger?
  19. Oct 20, 2017 at 6:25 PM
    #4359
    tacotime1
    I’ll attempt it myself for sure.
  20. Oct 20, 2017 at 6:26 PM
    #4360
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    That’d be my guess..you can buy the tune up kit on eBay for around $86....comes with everything you need.
