TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Feb 24, 2016 at 7:39 PM
    #1481
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Who is responsible for this masterpiece?
  2. Feb 24, 2016 at 7:39 PM
    #1482
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The owner in the video.
  3. Feb 24, 2016 at 7:41 PM
    #1483
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    That thing is wicked!!!!!!!!!!!!
  4. Feb 24, 2016 at 7:42 PM
    #1484
    WOODEX M.E.
    Corey
    Maine
    Curious if he was a member here or on xru
  5. Feb 24, 2016 at 9:07 PM
    #1485
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    XRU.
    Currently making ~1000 hp.
  6. Feb 25, 2016 at 3:36 AM
    #1486
    ThomasMore66
    Dallas/Fort Worth & Durango
    We should invite him to our party. 1000hp... Wow. What rear end?
  7. Feb 25, 2016 at 10:10 AM
    #1487
    RunsGuns
    RunsGuns Well-Known Member
    Sam
    Colorado
    Previously SC LT ‘12 taco. ‘95 FZJ80.
    Thanks man, i jusg spoke with a toyota service adviser at the local dealership and he said the supercharger doesnt need any servicing other than the belt changed.
    Does he just not know what he's talking about?
    When should i do the service with the kit you mentioned?
    If its a snout rebuild and bearing repair kit does it work with reduction pulleys? Or if i plan to change the pulley should i just do all this at the same time?
    Thanks for your help.
  8. Feb 25, 2016 at 10:30 AM
    #1488
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dude, 99.99% of the service guys at Toyota dealer don't know shit past regular maintenance. You bring up any sort of issue or extra service that isn't covered under regular maintenance and you get alot of "I'll get back to you on that one" or just bullshitting you to get you to go away. I gave up on going to the dealership for anything past warranty claims and parts.
    WOODEX M.E. and RunsGuns[QUOTED] like this.
  9. Feb 25, 2016 at 10:51 AM
    #1489
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Is the s/c organic and self healing, or mechanical? Ask them that.
    Biscuits and RunsGuns[QUOTED] like this.
  10. Feb 25, 2016 at 11:25 AM
    #1490
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    X2 on the above comment on the service dept. The rebuild maintenance kit should have no bearing on you changing pulleys.....unless there is something here I'm missing. Maybe torspd or volcom can chime in on this one. I would do it all at the same time....so you its done and when it was done.
    RunsGuns[QUOTED] likes this.
  11. Feb 25, 2016 at 12:47 PM
    #1491
    RunsGuns
    Sam
    Colorado
    Youre right on that one, i mentioned the rebuild kit and service and he was like "ugghh hangon" then a different voice came on and told me the above ^. Trust me i value the experience and reccomendations of the guys on this forum way more than a service adviser that drives a camry.
  12. Feb 25, 2016 at 12:56 PM
    #1492
    RunsGuns
    Sam
    Colorado
    Where is the best source for learning how to do the following
    -M90 eaton sc maintenance kit
    -change stock pulley to 2.85" urd pulley
    Any links to write ups or videos?
    Ive only done minor maintenence to vehicles. Working on the SC is past my current skill level without step by step guides and the last thing i want to do is fuck anything up.
  13. Feb 25, 2016 at 12:58 PM
    #1493
    RunsGuns
    Sam
    Colorado
  14. Feb 26, 2016 at 12:16 AM
    #1494
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Are TRD superchargers still extinct/the ones that aren't are insanely expensive?
  15. Feb 26, 2016 at 5:27 AM
    #1495
    WOODEX M.E.
    Corey
    Maine
    They are prety much gone as far as buying a new one. I think gadget at urd had some left recently, but that was about 2 months ago and there was about a $1500 markup if i remember.
  16. Feb 26, 2016 at 7:07 AM
    #1496
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    For some reason these guys at the service department are incapable of thinking for themselves. A simple question is the rule of thumb I always follow. "Does it have moving parts? If yes, then yes it will require maintenance"
  17. Feb 26, 2016 at 9:28 AM
    #1497
    Ihatetacomas
    Dylan
    Elko NV
    Ugh. Dreams are crushed. I guess I'll go with URD's s/c
    RunsGuns likes this.
  18. Feb 26, 2016 at 9:34 AM
    #1498
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    pretty much the same price as the Magnuson option too with a real computer and putting down way better numbers. I'm rebuilding a MKII URD setup at the moment, shooting for 350-375 WHP and around the same TQ on his stage 1 tune with stage 2 supporting modifications and new ARP headstuds. Per Gadgets recommendation should keep the truck way more reliable. Going to do Rods, Pistons, Valves and Springs down the road too.
    Biscuits and Torspd like this.
  19. Feb 26, 2016 at 9:39 AM
    #1499
    tubbsisland
    Cliff
    Arizona
    Agreed. its been "in the works" for too long. I suspect now that the 4.0 is out and Toyota has stopped making changes something will hit the market relatively quickly. My kit came with an APR X-One which I'm not too happy about but it is a little easier to tune after the fact than the Ucon
  20. Feb 26, 2016 at 9:43 AM
    #1500
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I was lucky to find one my buddy had sitting in his garage for 8 months. They are out there, but rare.
