TRD vs. non-TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomakid, Jul 13, 2008.
  1. Jul 13, 2008 at 12:27 AM
    tacomakid
    tacomakid [OP] Active Member
    sacramento
    2005 tacoma pre-runner
    3" revtek lift (6" lift coming soon), Rancho RS5000 shocks, magnaflow catback, K&N intake.
    ok so ive heard a few different answers to this question so i decided to try n get more answers.
    1. are the TRD tacos' wheel wells bigger than the non trd's?
    2. is the trd's stock height higher that the non trd's?
    3. are the 4X4's wheel wells bigger than prerunners?
    4. is the 4X4 stock height higher than the prerunners?
    :confused:
  2. Jul 13, 2008 at 1:22 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    1-You mean base model?? not sure. #2yes,#3 no, #4 no
  3. Jul 13, 2008 at 5:10 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ^^correct....#1 no.....but if u mean sr5/prerunner/non-trd 4x4/ then #1 yes #2 no #3 no #4 no
    EDIT: correction of yes to no
  4. Jul 13, 2008 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The wheels wells are all the same.
    The stock height is the same if the models you are comparing have the same size tires.
    The double cabs are .2" taller than the other modles.
  5. Jul 13, 2008 at 7:07 AM
    das56170
    das56170 Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    i thought that all the 6 lug tacos were pretty much the same height. 245/75 r 16 and 265/70 r16 and 265/65 r 17 which are found on the sr5, trd offroad, and trd sport respectively are all the same height tire within 0.1 inches. the width of the tires is different. my truck is a non trd 4x4 and before i lifted it, it was exactly the same height at the trd trucks (prerunners and 4x4)
    Now, if you're talking about a 5 lug taco...they are a lot lower than the 6 lug and have smaller tires and wheels 215/70 r 15
  6. Jul 13, 2008 at 10:28 PM
    tacomakid
    sacramento
    well the only reason i ask is that i did the 3" revtek lift n i hav sum 34" tires. n ive seen pics of other tacomas with the same thing BUT they look higher than mine. mine is a prerunner SR5. the other trucks look like they have more clearance.
  7. Jul 14, 2008 at 5:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you check your messurements against what it was when stock? Your springs may have sagged.
