Trd wheels worth it?
Discussion in 'Wheels & Tires' started by OSOQWK, Dec 24, 2011.
  1. Dec 24, 2011 at 12:44 AM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    K & N Air Charger Pioneer 920B Black Head lights Black Tail lights Color Matched Grille Hids
    Thinking about upgrading to the Trd wheels, see them on eBay daily... Having a big problem with the stock wheel rusting... Yes I keep them clean and dry.
    Do the Trd wheels weigh less than the stock wheels???
    Through the Internet Im seeing weight claims of60lbs for the Trd wheels and stock tires....
    Anyone know the weights of the stockies?
  2. Dec 24, 2011 at 12:49 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Are you referring to the beadlocks?
  3. Dec 24, 2011 at 12:57 AM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    Minimal rust there, it's primarily on the edges of the spokes, where bare metal is exposed, the finish does not extend there, and rust accumulates.
  4. Dec 24, 2011 at 1:01 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    their is a thread for the exact weight of the TRD off road wheel. i don’t know why i want to say it’s like 16 ponds a wheel.
  5. Dec 26, 2011 at 1:00 AM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    Which TRD wheels are you refering too? Sport wheels 17" / TRD off-roads are 16" I switched from the Steelies to the TRD rims for the FJ (16"). I noticed zero difference in performance or MPG's.
  6. Dec 26, 2011 at 10:40 AM
    af-flyboy
    af-flyboy Jesus Didn't Tap
    Alexandria, VA
    07 Taco DC/SB Sport 4X4
    Fox 2.5 C/Os w/RR, TC UCAs, Wheelers SuperBump Bumpstops, Rear TSB Leaf Springs & Bilstein 5100s, Elusive Elements Light Bar Behind Grill, Horn Relocation Mod, AFE Pro Dry S Cold Air Intake, JBA Cat-Back Exhaust, EBC Greenstuff 6000 Brake Pads, Black Grillcraft MX, BHLM, Blacked Out Valence, Tailgate Lock & Alarm Mod, Weathertech Floor Liners, Mag Light Mod, Aftermarket Tunes / Alarm, Interior LEDs, Broadway Rearview
    Toyota refinished my '07 Sport wheels after the warranty period was up due to rust issues...worth a shot, unless you're in the market for new wheels. Just sayin'...
  7. Dec 26, 2011 at 10:47 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Worth it? Not if you need different back spacing for larger tires after a lift or whatever. :cool:
  8. Dec 26, 2011 at 11:39 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    post a link or pic of which trd wheel you are referring too so we can help you out. fyi, the fj trd is 23-24lbs and the trd beadlock is 25-26lbs which imo is pretty heavy for a 16" wheel. the overall weight with tire can vary depending on the tire size, type of tire, and tire brand you're using.
  9. Dec 26, 2011 at 12:10 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    See if you can get a set of TRDs from someone getting new wheels (TW Member or Craigslist). I picked up a set from a local on Reno4x4.com for $100.
  10. Dec 26, 2011 at 12:16 PM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    what trd wheels are you taking about
  11. Dec 26, 2011 at 12:43 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
  12. Dec 31, 2011 at 2:10 AM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    The ones that come with a Trd pre runner Tacoma. I thought only fjs came w 16s
  13. Dec 31, 2011 at 3:28 AM
    4Wheelin4Banger
    Randy
    I thought only TRD Sport Tacos have 17" from '05 to '11 not sure what the '12s get except that the Sports are now 18".
