tried the search button
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowgod06, Nov 9, 2009.
  1. Nov 9, 2009 at 12:41 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so im going to be getting my all pro front bumper soon. Wondering how far your front dropped with the added weight. I have a non-trd with factory coils and a revtek spacer up front, 4X4. Trying to decide if i may have to get some new shocks upfront if it sags to far. thanks
  2. Nov 9, 2009 at 12:51 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    That is a lot of weight added to the front. I would consider replacing the spacers with OME 885s coils at the least
  3. Nov 9, 2009 at 1:01 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ive heard a 1/4 to 1/2 inch of sag.
  4. Nov 9, 2009 at 1:49 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    No it's really not, the stock bumper weighs in the neighborhood of 50lbs with everything on it and the All pro is about 110lbs according to all pro. So really your only adding about 70ish lbs to be safe. That's a couple cans of soda and a nice steak for most :p
    To the OP, I would get the bumper put it on and measure before and after to see how much "sag" you will get. If you feel it's too much get the Bilstein 5100 and set them at 1.75". If you go with the EMU 885's you will most likely need after market UCA's (upper control arms) that range from $450-$670 because they are a lift of 2.5-3" without the bumper. Anything over two, you may have a hard time getting your alignment into spec.
    Oh and I have the All Pro bumper and the Off Road Coils and it only "sagged" about 3/8 of an inch. Check out my build for before and after pictures.
  5. Nov 9, 2009 at 1:50 PM
    DanGer
    Oh wow, thanks for clearing that up, I had no idea it was that light!
    At the same time I now hate you cuz I want one now :p
  6. Nov 9, 2009 at 1:58 PM
    Masada
    Taylor
    Laveen, AZ
    LOL no problem, to test out if I would need new coils I stood on my front bumper and had my dad measure it. It wend down about 1/4 inch and I weigh 275Lbs. I can't say if this is do to my TRD OR coils or just a very stiff suspension in general but I haven't noticed any major problems with the stock coils.
    Now that's not to say at some point I will upgrade to the 885's and get new UCA's, but that's just because I want them not need them. As it sits now I don't see why I would ever need to put new coils on it.
  7. Nov 9, 2009 at 9:56 PM
    snowgod06
    Rob
    06 Access Cab
    thanks for the info. Ill check it all when it arrives and see what the situation is.
  8. Nov 9, 2009 at 10:36 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    post up some pics when you get it...i loveee the all pro front bumpers!!!
  9. Nov 10, 2009 at 4:34 AM
    snowgod06
    Rob
    06 Access Cab
    i will for sure. just waiting on a check in the mail so i can get it. Also got a set of the sliders as well from a member on here Jedidiah. That are allpro also, so its like an early Christmas for me :)
  10. Nov 10, 2009 at 4:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    DO NOT DO WHAT MASADA IS SUGESTING.
    Combining a 3" preload spacer with Bilstien 5100' set at 1.75" will esentially remove any suspension travel you have. If getting a heavier bumper, get some front srings that are designed for it. Either 885's, etc. Simply adding more preload to an OEM spring until the lift you are looking for is NOT very smart.
  11. Nov 10, 2009 at 7:19 AM
    Masada
    Taylor
    Laveen, AZ
    No really sure what is being said here? I didn't mean to suggest getting a spacer lift...I'm confused:confused:
  12. Nov 10, 2009 at 7:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    he is already running a 3" Revtec lift, and you are suggesting to add 1.75" preload to it.?? Thats way too much preload to add. If he is getting unnessesary sag (or unwanted sag) with a 3" lift already, its time to upgrade the springs to some that will do the desired job. NOT to add more preload to the OEM spring.
  13. Nov 10, 2009 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dgerm had it right. A 110# bumper is alot of weight added to the front of the truck. The OEM bumper is not 40#. Its about 5# platic, and 10# of aluminum. Maybe a little more.
  14. Nov 10, 2009 at 7:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    And even if it was 40-50# DOUBLING that, before a winch, is a LOT of weight.
    I'd get the right equipment/parts to support the bumper you are planning on instead of trying to make it work with a spacer lift.
  15. Nov 10, 2009 at 7:39 AM
    Masada
    Taylor
    Laveen, AZ
    Ah this is where the confusion was...I didn't see that the OP was running a spacer lift already:eek:. I get what you are saying now Chris LOL :D
    Bilsteins + 3" spacer + All Pro Bumper =
  16. Nov 10, 2009 at 7:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if you adjust them more than the 0" setting. :)
  17. Nov 10, 2009 at 7:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Photo however = WIN!!!
  18. Nov 10, 2009 at 7:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2! :laugh:
  19. Nov 10, 2009 at 7:49 AM
    Masada
    Taylor
    Laveen, AZ
    Google + Fail image search = unlimited success!
  20. Nov 10, 2009 at 8:04 PM
    snowgod06
    Rob
    06 Access Cab
    what would those coils set me back? where could i get them? is that all i would need would be coils?
