tring to hitch a tt
Discussion in 'Texas' started by doggear50, Sep 13, 2013.
  1. Sep 13, 2013 at 7:07 PM
    doggear50
    doggear50 [OP] New Member
    tx
    2010 prerunner sr5 texan addition
    listen i have a 2010 texan addition SR5 prerunner.today i spent all most three hour waiting on a hitch to be install. i plain on pulling a 19 ft travel trailer. well this is my first and getting info from here and there.is starting to get a bit costly. after i got the hitch . i found out that i will need a light kit to towed the trailer . i will need a stinger , a ball, and hitchpin is this all or what , can i get a little help stop the bleeding here.can i get a light kit cheeply or what:eek:
  2. Sep 13, 2013 at 7:11 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    If I read this correctly you need the wiring for the trailer plug and a brake controller?
    I bought my wiring kit at northern tool for 50 bucks. The brake controller can be expensive, where in tx are you?
  3. Sep 13, 2013 at 7:12 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    That is an extremely difficult post to read.
  4. Sep 13, 2013 at 7:15 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Yes it was I deciphered the hieroglyphics the best I could haha
  5. Sep 13, 2013 at 7:18 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    I deciphered none of it. Only "what"..
  6. Sep 13, 2013 at 7:19 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Hahaha ya i read it the best I could
  7. Sep 13, 2013 at 7:22 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Op can you re-word this please. It's a little difficult to answer a question we don't quite understand
  8. Sep 13, 2013 at 7:44 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    I thought this was about boobs...moving on
  9. Sep 13, 2013 at 7:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The Texas Edition trucks have the tow package, right? So there should be a 7-pin connector next to the factory hitch. Doesn't your travel trailer have lights?
  10. Sep 13, 2013 at 7:49 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  11. Sep 13, 2013 at 8:10 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Titties :D
  12. Sep 14, 2013 at 1:44 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Just go to auto zone, they have the wires fir the lights, ball abd all that stuff you will need.
  13. Sep 14, 2013 at 3:56 PM
    drunktaco
    Sage
    Southwest Va
    :goingcrazy:
  14. Sep 14, 2013 at 4:02 PM
    169.254.255.201 Well-Known Member
    Interwebs
    I'll give a shot at translating this...
    I have a 2010 texas edition SR5 Prerunner.
    I had someone put on a hitch. I don't know what class it is. I don't want to spend alot of money. I plan on pulling a 19 ft travel trailer, but I need a light kit to do so. I will need a stinger (what??), a ball hitch, and a hitch pin.
    Is this all I need, and how can I get cheaply made Chinese parts that will not only be unsafe for me, but for other drivers when my hitch pin breaks.
    /Done
  15. Sep 14, 2013 at 4:07 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yeah, this is what I understood. The Taco should be tow-ready. The travel trailer should hae lights. The converter from 7pin to 4/5 pin should have come with the taco. Lowes has some for cheap.
  16. Sep 16, 2013 at 8:40 AM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Weight Distribution hitch ($$)
    Brake controller ($$)
    Trailer Wiring (cheap one works fine, but it only get's you a 4 wire plug.. you need the 7 way plug..)
    You will need to run control wire from brake controller to 7way plug, and a good 12+ cable from the battery would be nice (not totally necessary). I did all this on my first Prerunner, it's not that bad. All the instructions can be found here on TW.
    If you plan on towing it frequently, Towing that trailer without the WD hitch and the brake controller is a mistake.
  17. Sep 16, 2013 at 1:44 PM
    169.254.255.201
    Interwebs
    What did samster007 say? It shows in my subscribed that he replied today but I don't see anything:der::notsure::notsure:
