Trouble sighting rifle, need help!!
Discussion in 'Guns & Hunting' started by Sigi, Sep 3, 2017.
  1. Sep 3, 2017 at 8:11 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I meant make sure the stock isn't putting pressure on the barrel. In had to get my stock fixed
  2. Sep 3, 2017 at 8:13 PM
    Sigi
    Sigi [OP] Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Do you think using sand bags and my shoulder as a support would work better?
  3. Sep 3, 2017 at 8:15 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    yes! for sure give it a shot. No pun intended.
  4. Sep 3, 2017 at 8:19 PM
    Sigi
    Sigi
    Sfv ca
    Oh I see, yes I'll check, thanks. Run a bill though it , right?
  5. Sep 3, 2017 at 8:19 PM
    Sigi
    Sigi
    Sfv ca
    Lol
  6. Sep 3, 2017 at 8:20 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  7. Sep 3, 2017 at 8:24 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    I've shot out of that type of sled before and I still held my rifle as I normally would,prefer sandbags for the fore end and that's it personally.sounds like it's just some float in the rest being used to me
  8. Sep 3, 2017 at 8:33 PM
    Sigi
    Sigi
    Sfv ca
    If I remember , I think i sighted my last rifle with just a bipod and have 1 inch groups at 100 yards. I'm going to try the sand bag in the front .
    LocoLocal likes this.
  9. Sep 3, 2017 at 8:39 PM
    elmontemike
    elmontemike Well-Known Member
    make sure the bolts that mount the stock to the action are properly torqued and there is no movement of the action in the stock.
    Nice looking rifle. I have the earlier version, the A-Bolt and love it.
    wilcam47 likes this.
  10. Sep 3, 2017 at 8:39 PM
    nizzmont
    Brian
    S.E WA state
    in progress
    That's a good way to go as well,that rifle should be a tack driver for sure...the scope makes me drool lol
  11. Sep 3, 2017 at 8:40 PM
    Sigi
    Sigi
    Sfv ca
    Thanks , I have an a bolt too. You think it can come not torqued properly from factory ?
  12. Sep 3, 2017 at 8:42 PM
    elmontemike
    I had a new Remington that was lose. Just 1 easy thing to rule out.
  13. Sep 3, 2017 at 8:43 PM
    Sigi
    Sigi
    Sfv ca
    Lol, thanks ! That's why I'm upset ! I spent so much and it shoots like crap. Lol . My old browning 270wsm that I bought in 2002 with a leupold vx-2 shoots 1 inch groups. Lol
  14. Sep 3, 2017 at 8:44 PM
    Sigi
    Sigi
    Sfv ca
    Came lose new? I need to check it out.
  15. Sep 3, 2017 at 8:49 PM
    #35
    elmontemike
    Yes, came lose new. When you installed your scope, did you follow the manufacturers installations instruction for the base and rings? Double check the screws. Even though you used lock-tight, they may have come lose.
  16. Sep 3, 2017 at 8:49 PM
    #36
    taco2010trd
    Tampa, Florida
    I have two Abolts, love them very accurate too
  17. Sep 3, 2017 at 9:18 PM
    #37
    Sigi
    Sigi
    Sfv ca
    I didn't use a torque wrench but I tightened everything tight . While at the shooting range I double checked , and everything was tights.
  18. Sep 3, 2017 at 9:24 PM
    #38
    trdude10
    trdude10 Well-Known Member
    Nick
    17 DCSB Trd OR 6sp
    I agree with the guys suggesting to check your stock touching the barrel and also checking the torque on your action screws. It is possible to over torque your scope rings and I have seen that cause horrible groups. with an expensive set up like that, why not use a torque wrench? You can get the wheeler one for fairly cheap. Even with shitty ammo your groups should be better
    elmontemike likes this.
  19. Sep 3, 2017 at 10:19 PM
    #39
    Sigi
    Sigi
    Sfv ca
    Yes I am planing on buying one. Thanks !
    I know It should be shooting tight groups.
  20. Sep 4, 2017 at 10:37 AM
    #40
    elmontemike
    I agree 100%. Let us know how it shoots after this.
