Trouble with A/C system...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DVS4.0, Jul 6, 2020.
  1. Jul 6, 2020 at 4:44 PM
    DVS4.0
    DVS4.0 [OP] Well-Known Member
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Toytec coils, Bilstein 5100's, Freedom Offroad UCA, Pro Comps Wheels, Spidertrax, 33's, Memphis Audio
    2013 DC, new filter and good charge and yes the A/C works on all speeds...
    On 2 separate occasions I have had the A/C fan output drop by about half of the normal output. System continues to cool just fine but the amount of air that comes out is about half at all settings. Both times i was driving the truck for about an hour. Once I let the truck sit (motor off) for about 15-20 minutes or so there will be a larger than normal puddle of water under the truck. Once I turn the truck back on the A/C will then blow just fine. Strange I know, just wondering if anyone has any experience with this?
    Almost seems as if something is freezing up, like a line or the evaporator core.
    Thanks for any help in advance...
  2. Jul 6, 2020 at 4:47 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Look at the fan speed resistor. It'll be near the blower motor. Unplug it and look in the connector to see if any of the terminals are corroded. Check the blower motor and HVAC control connectors as well.
    Kolter45, DVS4.0[OP] and knayrb like this.
  3. Jul 6, 2020 at 5:10 PM
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    thanks will look into these three areas.
    Larzzzz likes this.
  4. Jul 6, 2020 at 5:15 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    This.
    These are notorious for resistor connection burnouts. You can clean them and slightly bend the pin closer to the connection but the long term fix is to buy a connector kit and splice a new one on.
    DVS4.0[OP] likes this.
  5. Jul 6, 2020 at 5:28 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Large puddle as the evap thaws. The termistor in the evap is not stopping the freeze-up. Next time it does it, leave the truck running and immediately pop the hood. Look at the larger AC line where it exits the firewall. See any frost/ice?
  6. Jul 6, 2020 at 5:32 PM
    Larzzzz
    Larry
    MA
    I've seen pix of where that is. Oh gawd. You might as well do the heater and evap cores while your there...
  7. Jul 6, 2020 at 6:04 PM
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Will do the next time it does it. Can you elaborate a little on the Termistor in the evap?
  8. Jul 6, 2020 at 8:14 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    The thermistor is just a temperature sensor that attaches to the evap. It's purpose is to shut off the compressor if the evap is freezing up, allowing it to defrost, then the compressor will come back on. It's a tear apart the dash job to get to.
    @Jimmyh can explain the electrical part much better than I.
  9. Jul 7, 2020 at 8:17 AM
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Sadly, that sounds like what is happening. The A/C has been unusually cold since the last time it acted up. I will look into this thermistor thingy.
  10. Jul 7, 2020 at 3:38 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    In the meantime, when driving for an hour, turn off the AC for a few minutes every half hour. This will allow the evap to defrost and keep it from completely freezing up.
    And something folks don't realize... ice expands as it freezes creating a lot of stress on the parts it is freezing on/IN. And that creates evap leaks.
  11. Jul 7, 2020 at 4:01 PM
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    Noted....actually started doing this yesterday. Appointment set up for tomorrow to have the system checked. Thanks btw
    CurtB[QUOTED] likes this.
  12. Jul 7, 2020 at 4:10 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    That can also happen from low charge or low airflow over the evaporator.
  13. Jul 7, 2020 at 5:35 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not if the thermistor is doing it's job.
    Jimmyh likes this.
  14. Jul 7, 2020 at 6:59 PM
    DVS4.0
    Dan
    Deep South Texas
    2013 4x4 SR5 DC
    In my research today, i read this and really hope this is the issue. Hoping tomorrow will be a positive outcome.
  15. Jul 7, 2020 at 7:21 PM
    JohnMurphyNC
    JohnMurphyNC Well-Known Member
    Oklahoma
    2015 DCSB Superwhite 4x4 TRD Sport
    This is really clear and helpful.
  16. Jul 7, 2020 at 7:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Exactly this. When the evaporator gets to the low set point the compressor clutch is dropped off until the temperature rises above high set point which allows the compressor clutch to reengage again... Repeat... in a continuous cycle as long as the AC is turned on.
    TnShooter likes this.
