Truck died on me!!!!
Discussion in 'Technical Chat' started by DeeKay21, Jun 19, 2009.
  1. Jun 19, 2009 at 9:15 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    like on empty..and you do this a lot??
  2. Jun 19, 2009 at 9:16 PM
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    No, I let it run down a little before it hits the empty line but never empty.
  3. Jun 19, 2009 at 9:17 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    No fuel related issue. even though, running you're vehicle out of fuel, is never a good thing haha
  4. Jun 19, 2009 at 9:18 PM
    vwguy60
    vwguy60 Well-Known Member
    Southern California
    2009 TRD Sport DC LB
    Toytec Ultimate Lift Kit, TC ucas, TRD CAI, powder coated OEM tube steps, powder coated TRD skid plate.
    With the engine running, pop your hood, grab a voltmeter and check the + and - on the battery. Running it should be over 14 volts, this means your truck's alternator is providing power to charge the battery. If it is not, it is something to do with your charging system, most likely the alternator.
    Also, check the battery again with the engine off. You want to put a load on the battery. Most shops will have a load tester that puts a load on the battery. You can do a quick test by turning the key on (keep the engine off) and turn on your headlights. If your battery dips down to under 10.5 volts it most likely needs to be replaced.
    That is a start to you diagnosis, hopefully it points you to something obvious.
  5. Jun 19, 2009 at 9:20 PM
    REVHARD25
    so cal
    then check all electrical connections ..plugs..alt ..battery ..cap and rotor..even air intake check everything before you take it in and have them charge you up your butt for a simple thing
  6. Jun 19, 2009 at 9:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    bingo! :)
  7. Jun 19, 2009 at 10:07 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ran to the store and got a volt meter. Ima go check it now.
  8. Jun 19, 2009 at 10:16 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Put a meter on the alternator and see if it's charging. If it's the alternator the battery should be dead, head lights working?
  9. Jun 19, 2009 at 10:26 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah head lights are working.
  10. Jun 19, 2009 at 11:38 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well, battery was pretty much dead. Put in a new one and everything works great. Went to the gas station and filled her up to. But I guess it can still be an alternator problem huh?:confused: Got to drive about 300 miles this morning. Should I chance it?
  11. Jun 20, 2009 at 6:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need to check that alternator. If its bad, its gonna take the new battery with it.
  12. Jun 20, 2009 at 6:21 AM
    vwguy60
    Southern California
    Exactly!
    I just responded to your PM too. Do the "engine running test" so do you have over 14 volts?
    If you do, have a beer because you fixed it. If you have 12.6 or lower, you are not done yet.
  13. Jun 20, 2009 at 6:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was thinking 13.2 or less......:eek:
  14. Jun 20, 2009 at 6:27 AM
    vwguy60
    Southern California
    Good morning Chris!
    Yes, 13.2 will still be a weak charging system but only battery voltage will mean a completely dead one. It could go either way...
    He needs to report back with the engine off test voltage and the engine running voltage for us to give him a complete answer.
  15. Jun 20, 2009 at 6:33 AM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Morning, Buddy. :)
    Correct.
  16. Jun 20, 2009 at 6:42 AM
    #36
    vwguy60
    Southern California
    Report back, hopefully before your 300 mile drive. I will be unavailable for part of the morning and in the afternoon. Dogs are going to the groomers finally and I have to do some honey-do's.
    Before you say just brush them yourself here is their pic:
    I do and it is tiring! Plus they kinda stink, my big white dog chews on the wife's smaller dog like a chew toy.
    Chris or I should be able to give you advice but we need to know what the voltages are. Hopefully one of us will be here when you do. Good luck!
  17. Jun 20, 2009 at 6:43 AM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And I will be out of town until this evening.....Good luck, Danny.
  18. Jun 20, 2009 at 6:45 AM
    #38
    vwguy60
    Southern California
    Ok, with Chris gone, I will try to answer from my phone.
  19. Jun 20, 2009 at 7:20 AM
    #39
    fletch aka
    Gary
    Left Coast
    TW rocks, way to step up.
  20. Jun 20, 2009 at 7:23 AM
    #40
    vwguy60
    Southern California
    I love my iPhone!!!
