Truck Doesnt Start Sometimes?
Discussion in 'Technical Chat' started by jeckel7234, Jul 2, 2011.
  1. Jul 2, 2011 at 11:26 AM
    jeckel7234
    jeckel7234 [OP] Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    05 DCLB 4.0,
    I got my truck a little more than a month ago and for the most part it starts everytime, but about 1 out of every 10 times the motor cranks for an extended amount (8sec +/-) of time and wont start. But as soon as i let off and turn the key again it starts right up, its really annoying and hard to troubleshoot being that it doesnt happen all the time without throwing alot of money into it. Any Ideas
    Thanks
  2. Jul 2, 2011 at 11:41 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Starter may be going out
  3. Jul 2, 2011 at 11:42 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    x2
  4. Jul 2, 2011 at 11:43 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    Is there a way to test the starter
  5. Jul 4, 2011 at 6:13 PM
    jeckel7234
    Drew
    VA
    05 Tacoma
    bump,
    maybe my original terminology was wrong, the motor turns over but wont start then i let off the key and it starts right up , had the starter tested it was good,
  6. Jul 4, 2011 at 6:45 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Could be the bendix gear spring on the starter, this can cause the exact symptoms you describe.
  7. Jul 4, 2011 at 8:21 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    my 11 does that too
  8. Jul 4, 2011 at 9:18 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    hey man i'm too lazy to dig up the link again, but there is a TSB for this. do a search for hard start or won't start or something to that effect. i put up the link in another thread about this very same thing just a week or so ago. good luck w/ it.
    ps, it should still be covered even if your truck is no longer under 36K mile warranty.
    the fix is...they re-flash the computer or something like that.
  9. Jul 5, 2011 at 11:34 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    Thanks alot man, i found it TSB EG011-07 it only cover 05-07, and is only good within 96 mos or 80,000 mile my trucks at 90,000, so toyota wants 150 to reflash the ecu
  10. Jul 10, 2011 at 5:11 PM
    ryguy
    ryguy Well-Known Member
    Riley
    Central California
    06 Silver Double Cab 4x4 TRD Sport
    does the door chime when it is open with the key in? Because i did the mod where you disconnect the harness next to the ignition to stop the chime when the door is open and your key is turned to acc. When i did this it would do the same exact thing. Every so often the truck would just try and start but wouldnt get there. then i would let off and try again and it would start right up.
    so i reconnected the harness and everything works like new again. No problems. I would check that. The previoius owner could have done that mod and lived with the false starts.
