Truck has no spark please help
Discussion in '4 Cylinder' started by marsk5, Apr 30, 2010.
  1. Apr 30, 2010 at 1:38 PM
    marsk5
    marsk5 [OP] Member
    marshall
    louisiana
    1996 tacoma 2.7 5spd 4x4
    3" susp lift 3" body lift
    i recently changed the head gasket and hooked everything back up now i dnt have any spark to the spark plugs, i changed the ecm and the igniter and nothing has worked. any suggestions would help me out alot. the truck is a tacoma 4x4 with a 2.7 5spd
  2. Apr 30, 2010 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check your ground wires. Also, Make sure you have the Cam timming set correctly.
  3. Apr 30, 2010 at 6:18 PM
    marsk5
    marsk5 [OP] Member
    marshall
    louisiana
    how do you check the cam timing?
  4. Apr 30, 2010 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You removed the head, Right? Did you not check to make sure everything was aligned propperly? Chain, Cams, etc.?
  5. Apr 30, 2010 at 6:44 PM
    lilblucoupe
    lilblucoupe Member
    ky
    96 tacoma 4x4
    i have the same problem, as of now we my crankshaft position sensor was broke off and i think it looks as the crankshaft timing gear is broke also. i know it has a flat spot but looks like its broke, im gonna take a better look tomorrow. GOOD LUCK!!!
  6. May 1, 2010 at 8:01 AM
    marsk5
    marsk5 [OP] Member
    marshall
    louisiana
    i just found that my igintion coil was broke so im guna replace that and see if it fixes the problem
