truck is shaking!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Mar 16, 2010.
  1. Mar 16, 2010 at 2:27 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    i hit 70 - 80 mph and i looked over and my passenger seat is shaking like crazy! like seizure shaking. so i hit up discount tire and he reduced my tire pressure to 35, when they installed it last month they had it at 40, i havent tested it out since he reduced it but does anyone have this problem or has had this problem? im hoping it was just the tire pressure
  2. Mar 16, 2010 at 2:28 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    I know that with stock tires, my passenger seat normally shakes at normal speeds, but not too bad.
  3. Mar 16, 2010 at 2:31 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    mine shakes between 58-68mph give or take. It did it before my stock wheels too so its not a wheel balancing issue. I wish i knew what it was its quite an obvious shake. Nothing too crazy but I have watch my steering wheel shake a bit and my shifter.
  4. Mar 16, 2010 at 2:32 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Have them rebalanced, maybe you threw a weight.
  5. Mar 16, 2010 at 2:33 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    If it's just the passenger seat shaking, perhaps it's loose?
  6. Mar 16, 2010 at 2:33 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    x2
  7. Mar 16, 2010 at 2:36 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    40? what tires are you running... I run mine between 29-32 psi on BFG AT's.. 265/70/R16.
  8. Mar 16, 2010 at 2:37 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    if its ONLY the seat shaking i would say its loose. if you have vibs coming from the steering wheel or floorboard then you should investigate further. but look at the seat first. since you say that was the only thing moving.
  9. Mar 16, 2010 at 2:38 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    why not just take it out and test it again? same road, and everything.
  10. Mar 16, 2010 at 2:40 PM
    Jester243
    Dan
    Spokane, WA
    The passenger seats move a little whenever there is no one in them. However if it is suddenly more pronounced then I would have the balance rechecked, they should be able to do that for no charge.
  11. Mar 16, 2010 at 2:45 PM
    Marioso
    San diego Ca
    too many to quote but, its not my passanger seat only, eveything in my back seat, steering wheel. im running 285/75/r16 stock rims.
  12. Mar 16, 2010 at 2:45 PM
    Marioso
    San diego Ca
    oh no, theyre shaking like CRAZY
  13. Mar 16, 2010 at 2:47 PM
    Jester243
    Dan
    Spokane, WA
    ok...but did it become suddenly worse or just since the tires were done and aired up to 40 psi?
  14. Mar 16, 2010 at 2:49 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    your not running bias ply tires are you? stupid question but.......
  15. Mar 16, 2010 at 2:51 PM
    Marioso
    San diego Ca
    maybe 3 days ago i noticed
  16. Mar 16, 2010 at 2:52 PM
    Marioso
    San diego Ca
    whats that?
  17. Mar 16, 2010 at 2:53 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    I lost the bottom bolt of my shock once and that made my life hell.. check that stuff. Something should be obvious. if it isnt, get them balanced and that'll answer that.
  18. Mar 16, 2010 at 2:53 PM
    Jester243
    Dan
    Spokane, WA
    I guess you could also have a tire seperating on you. Just have a tire shop check em then go from there. It is just too hard to diagnose over the interwebs like this sorry.
  19. Mar 16, 2010 at 2:54 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Yup. whatever you do, do it quick before you ruin something or kill someone.
  20. Mar 16, 2010 at 2:56 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    also if your running alloy wheels are the shop used an impact gun without a torque stick. they could have warped the rim. but like every 1 says its are to diagnose over the web.
