Truck is throwing that damn P0101 code!! (SOLVED)
Discussion in 'Performance and Tuning' started by novanut21, Jul 6, 2015.
  1. Aug 1, 2015 at 12:21 PM
    novanut21
    novanut21 [OP] Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I drove about 40 miles round trip today and check engine light did not come on, but watching the AFR gauge it would occasionally spike lean with cruise control on or off @ 65-70 mph. It still pegs the AFR gauge lean when bringing up rpms and holding them at around 2k in any gear which I don't understand. I did take air filter off and tried 1st and 2nd gear up to 2k and both times in both gears it went lean bouncing around 16:1.
  2. Aug 1, 2015 at 12:30 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I'm going to try and duplicate the 2k lean condition with my scan tool hooked up and try and record some data. I don't know what else to do.
  3. Aug 1, 2015 at 5:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Try re-attaching the vacuum hose from the intake, back to the FPR.
  4. Aug 1, 2015 at 7:55 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I found the brass nipple for the intake I just need to get some vacuum hose in the AM.
    Torspd[QUOTED] likes this.
  5. Aug 2, 2015 at 9:27 AM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I reattached the vacuum hose from the intake to the FPR - no change in AFR
    I reattached the vacuum hose from FPR to the tee for boost gauge to make it boost referenced - no change in AFR
  6. Aug 2, 2015 at 10:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Interesting.
    You did clean the MAF sensor as well, correct?
  7. Aug 2, 2015 at 7:43 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Yes, I did I forgot to mention that I cleaned my new MAF sensor when I took the air filter off. This thing has me completely stumped.
  8. Aug 3, 2015 at 6:09 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    What air filter are you running right now?
  9. Aug 3, 2015 at 6:28 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Let your your FPR connected to the T of the boos t gauge.
    When you say seeing reading lean like 16-18, how much time you see it. If its only for 1 sec it's normal. When applying throttle the reading always go lean and when getting off the reading is going rich.
  10. Aug 4, 2015 at 5:21 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Hey I don't see the fuel reference.Vacuum line from your plugged fitting on air tube by air box?on my 2005 4x4 auto.Has one .I don't know about your year.in goes from air tube to pass side fuel rail as a reference to add fuel. Again on mine.
  11. Aug 4, 2015 at 5:35 AM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Looked at your pictures.Why is fuel reference pod at back of pass fuel rail capped off??Air tube brass plugged also.Engine needs Its Inputs And That is a Major reference!!blow up my picture and u will c 1/4in.line 1/8in inside is for fuel control.Plastic line past my Maf is for meth injection.rubber line between air box and Maf is fuel boost reference.Agaian on mine.I have trd blower urd uconn.Controler 7th.injector meth injection 2.74 pulley jab.headers Doug throully.pipebomb y. Pipe
  12. Aug 4, 2015 at 5:58 AM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Ps.upgraded fuel pump from urd.rear O2 simulater.I have not had engine issues but the auto tranny.at 7000rpm.Yes 7000rpm isn't happy with me.A Joke 4 All what do you get when you mix a TRD with URD? A Turd Rite.But My Shit Is Fast!!!!! Good luck.I believe that is your issue.fuel reference.
  13. Aug 4, 2015 at 8:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Create a build thread!
  14. Aug 4, 2015 at 7:15 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE Pro Guard 7
    If I hold steady 2,000-2,200rpms setting still or driving it goes lean 16:1 -18:1, if I punch down on it and get into boost it will richen up. I afraid to hold to too long with it being that lean but I have done it a few times now for up to 30 seconds with it not moving out of the 16:1 - 18:1. The truck just doesn't feet right I can't explain but you just know when somethings not right.
  15. Aug 4, 2015 at 8:28 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Let me refresh. When you drove with the filter off, you no longer received the CEL, but that area of load and rpm still creates the lean issue?
    Is this a relatively new lean condition? If so, did it happen immediately after any specific mod or event?
  16. Aug 4, 2015 at 8:39 PM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can you a picture of the throttle body. Directly above it, looking straight down at it? From your previous pictures, it might not be visible, but it looks like there isn't a gasket between the TB and s/c.
    Not sure how many miles are on your truck, but reading one of your earlier threads, you did the URD fuel pump installation correct? If so, have you changed the fuel filter since then?
  17. Aug 4, 2015 at 8:47 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    AFe oiled version.
    Novanut, you never mentioned that you had cleaned the oil from the air filter. Did you spray it down with any degreaser to get the oil off?
  18. Aug 5, 2015 at 2:39 AM
    #38
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    7K!?
    @Torspd u member what werty was at when he went boom?
  19. Aug 5, 2015 at 6:07 AM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    6200 RPMs, on stock internals. Somewhere around 8 psi or a tad more. TRD S/C. Rod/rods shattered.
  20. Aug 5, 2015 at 6:39 AM
    #40
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I guess this is soon to be werty 2.0
