Truck is throwing that damn P0101 code!! (SOLVED)
Discussion in 'Performance and Tuning' started by novanut21, Jul 6, 2015.
  1. Jul 13, 2017 at 7:55 AM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wouldn't hurt. I forgot about that. Might just be in the plug itself. Just a connection which isnt as good as it could be.
    mightytacoman likes this.
  2. Jul 13, 2017 at 12:01 PM
    #62
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I was researching poor mans way to check for vacuum leaks. Came across an interesting idea. Put a rubber glove over the afe intake tube to seal it. Remove passenger side vacuum line (just past maf sensor) from block, light up a cigar and blow smoke into the vacuum tube (engine off). The smoke with travel down past the throttle body etc and if there is in fact a vacuum leak, should come out of the leak. This will show you precisely where the leak is if there is one. Much cheaper than a smoke machine. For the price of a cigar, I figure its worth a shot. Tomorrow I got the day off to really tear into it and sort it out.
    Torspd likes this.
  3. Jul 13, 2017 at 4:24 PM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Interesting. Worth a shot. Xpotopr found a vacuum leak on the blower cap, near the drive pulley. Had to use silicone to reseal the cap.
  4. Jul 14, 2017 at 7:18 PM
    #64
    mightytacoman
    Kel
    4.5L 1grfe
    My cigar trick did work. Found a small leak right where the maf sensor goes in. However, it didn't fix the issue. Ran a wide band sensor off the exhaust and pulled a spark plug. All showing signs of running lean. Ripping the charger off tomorrow to look deeper into things
  5. Jul 14, 2017 at 11:46 PM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How far down the rabbit hole will we go....?
  6. Jul 15, 2017 at 4:43 PM
    #66
    mightytacoman
    Kel
    4.5L 1grfe
    Well ripped the charger off. Cleaned it up. Little build up of grime here n there. Cleaned the bypass valve, cleaned the vsv, checked plugs both sides (showing lean) cleaned injectors and bench tested them. Found a small possible kink in the pcv valve line leading back from the catch can to the super. 90° elbow installed on that to remove an potential of future kinks. Potential kink in coolant line that goes through firewall. Fixed that. Installed new fuel filter. Hollowed out driver catalytic, (passenger side broke apart and fell out 20,000 ago) figured this way both sides match in case that was an issue. Headers were magnaflo high flow headers with built in cats. Now they're basically long tubes. Got it all back together and now I see a gas leak at the injectors, so I gotta redo that.. Again
  7. Jul 15, 2017 at 9:26 PM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I applaud the thorough breakdown.
    S/c cap: I imagine the mating gasket is a bit thin and or worn down. Did you add silicone to it?
    Injectors: do you add Vaseline or some other lubricant to the o'rings before pressing them into the fuel rail?
  8. Jul 16, 2017 at 12:20 PM
    #68
    mightytacoman
    Kel
    4.5L 1grfe
    Sc cap gasket looks brand new and showed no signs of a leak. On second tear down, I added Vaseline to o rings. No fuel leak now. seems to be running better. Still seems lean. Should know more after the ride to work tomorrow
  9. Jul 16, 2017 at 12:27 PM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    One problem down.
  10. Jul 18, 2017 at 7:23 PM
    #70
    mightytacoman
    Kel
    4.5L 1grfe
    Been a couple days since my last update. Spoke with gadget and he mentioned swapping back to the stock intake. Well I tried that without any luck. Truck still throws the maf code, O2 sensors show super lean under load and actually a touch rich when not working the truck. Interesting to note, now that I've been watching my fuel trims for over a week now. I notice the long term trims tend to run +28%--+38% but when symptoms occur, they drop way down to +6%. I wish I knew more about how long terms trims work, but they jump all around when truck is acting up... Its really got me thinking is the walboro255 fuel pump. It's the only thing I haven't checked. I don't know a way to bench test it though. I could get the fuel rail tap from urd and a gauge to measure fuel pressure but that's about the only way I know and not a cheap option either.
  11. Jul 18, 2017 at 7:26 PM
    #71
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    From my understanding you need to run a fmu or regulator with the 255lph.
  12. Jul 18, 2017 at 7:34 PM
    #72
    mightytacoman
    Kel
    4.5L 1grfe
    They have stock regulators attached to the fuel rail to my understanding. Gadget recommended I get that fuel pump when I got the 2.825 pulley so I did. He didn't mention the fmu. I plan to call him again tomorrow regarding my issues. Hopefully he can shed more light on the subject. Thanks for the heads up. Those are both things I can ask him about
  13. Jul 18, 2017 at 10:48 PM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Might have a fuel hose problem, attached to the pump itself.
  14. Jul 19, 2017 at 4:28 AM
    #74
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No FMU is needed. The OEM regulator work decent enough. In my opinion, and that of the industry, it should be used with a vacuum/boost source. (I.E. FPR mod) However, without a tuning solution, it will just make the OPEN LOOP fueling overly rich until more boost is added, or tuning comes into play.
  15. Jul 19, 2017 at 4:49 AM
    #75
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Jul 19, 2017 at 7:07 AM
    #76
    mightytacoman
    Kel
    4.5L 1grfe
    Torspd, are you more inclined to believe its a kinked hose/damaged hose inside the fuel tank or the pump itself failing?
  17. Jul 19, 2017 at 7:17 AM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Most problems people have had with the pump upgrade, has been something with the installation of the hose. Kink, tear, split.....
    Investigation will prove if your hose does have a problem or not.
  18. Jul 19, 2017 at 7:46 AM
    #78
    mightytacoman
    Kel
    4.5L 1grfe
    Well that's an easy fix, be it a pain in the a$$ to get to. I'll rip the bed off this weekend to investigate and report back. I don't think I can use enough fuel to drop the tank by then and tank is currently full
  19. Jul 19, 2017 at 8:36 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To bad you don't have a jack that gets high enough. I use a little HF trans jack for the job.
  20. Jul 19, 2017 at 8:40 AM
    #80
    mightytacoman
    Kel
    4.5L 1grfe
    I've heard pulling the bed isnt much harder if not easier. I've dropped the tank 3 or 4x now. Now one of the straps is messed up and a pain to get back in place so I'll try removing the bed this time.
    Torspd likes this.
