Truck jerking before shifting gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnny5015, Apr 29, 2023.
  1. Apr 29, 2023 at 2:47 PM
    johnny5015
    johnny5015 [OP] Member
    2017 silver tacoma trd sport
    33in tires , rough country leveling kit
    Yea that’s what I thinks happening maybe I just am looking for it to do it now who knows tranny flush first then most likely getting the ott tune
    na8rboy likes this.
  2. Apr 29, 2023 at 3:14 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    I had the OVT and was good. Recently got another tune from MBP @moddedbyphil on IG. The shift is even way smoother than the previous OTT. No lag and has way more pep from the moment you put beans on it. Feels racy in a way which is cool.
  3. Apr 29, 2023 at 4:19 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You mentioned OVT tune, then OTT. Which did you previously have? I have OTT 7.0
  4. Apr 29, 2023 at 6:31 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    I had the Orange Virus Tune. Maybe it’s the same as what OTT is. And that was a typo. All I know is that there’s this software called VF tuner. You make your own tune out of it. There are many tunes out there that are modified based on what they’ve done to it. I’ve heard of Overland tune, Sibi tune, KD Max tune, etc. What I can tell you is this tune I have is smoother than the Orange Virus tune.
  5. Apr 29, 2023 at 7:00 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Welcome to the forum!
    Not sure if you purchased the truck new or pre-owned, but before the dealer performs the transmission service, ask them to confirm if any of the ECU updates have been performed/applied to specifically address and correct the shift and drivability issues the 3rd generation trucks had in their initial years of production. I understand from reading here that there have been several.
    Re: the a/c: My 2014 doesn't handle the a/c compressor load seamlessly when it kicks in either: there is a momentary engine RPM drop, then a small/brief over-rev as it recovers. You feel this mostly stopped in traffic, etc, but it can also be felt at speed on the highway. To be fair, this has been the case on all of my cars 4/6 cyl) with the exception of the ones that had a V8.
  6. Apr 30, 2023 at 4:41 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When I bought my tacoma in jan. of 2020, the dealer had informed me when I took delivery, the truck had all the latest tsb's performed, so I wouldn't need to have any further service than the 1st toyotacare visit 6 months from now. I gotta admit the transmission behaved goofy during the 160 mile trip back home, but by 1200-1500 miles it was working perfect, and has been since. It felt like the truck had some sort of break in circuit/chip till it had that mileage, then wow, it was a different truck overnight. No need for any tune, it's a rocket the way it is. I like it better than my gen1 tundra v8.
  7. Apr 30, 2023 at 8:59 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i've had this issue when i had water in my fuel or low octane. filled up with some higher octane fuel and the issue went away. as long as i use 89 octane or better, the issue hasn't happened again. recently used 87 again for several tanks for a long trip, and the problem came right back.
    tldr: i think it runs on knock sensors on 87 and it can make it drive like shit
  8. Apr 30, 2023 at 10:18 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    sounds like Munchausen's syndrome to me
  9. Apr 30, 2023 at 4:26 PM
    zoo truck
    None
    I can claim the gas in the midwest when I was out there isn't the same fresh quality as we get here in Connecticut, where it's off loaded 60 miles south of where I live. 87 grade with 10% ethanol works great in my truck.
  10. Apr 30, 2023 at 5:25 PM
    johnny5015
    I’ve tried running higher grade fuel I don’t personally notice a difference but I also didn’t try it for multiple tankfuls
  11. May 1, 2023 at 5:02 AM
    zoo truck
    None
    When I ran multiple tankfuls of 92 grade gas my truck, it just seemed to keep running sub par to what it normally runs using 87. Idk, or haven't seen any change, but I always try to fill up with a top tier brand fuel. Been using shell, or irving for the most part.
  12. May 1, 2023 at 7:44 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    if you don't reset the learned values, it can take at least 3-4 tanks to start noticing a difference. it takes a long time for it to advance the timing. it will retard it very quickly though to prevent knocking.
  13. May 1, 2023 at 8:10 AM
    Firn
    Firn Well-Known Member
    White OR
  14. May 1, 2023 at 11:00 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    My truck has done this since new as well (now at 22K), jerks around 45 mph when the engine is around 1800 rpm. This typically happens once the transmission shifts from 4th to 5th, keeping the truck in S4 helps. I have OTT (lite/mild) and didn't totally solved the problem. This weekend I decided to check the level of my ATF (3rd Gen Automatic Transmission Fluid Level Check DIY) and found that I was 10 oz low. I still need to drive it around a little longer to be sure but the vibrations seem to have improved. The mild setting on my tune also feels smoother when I accelerate from a stop. Fingers crossed this is the solution.
  15. May 1, 2023 at 12:01 PM
    #35
    zoo truck
    None
    On the subject of tunes for these trucks....has anyone with a tune run a new Nissan frontier. I got the opportunity to run against my buddies. Those trucks are pretty fast. I could stay about the same distance with mine till about 80 mph, then his frontier would slowly pull away.
