Truck lean? Leaf spring creak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Mar 19, 2011.
  1. Mar 19, 2011 at 10:52 PM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    I've been noticing a creak everytime I exit or enter the truck, and when I push down on the bed slightly. I've also noticed about a 2 degree lean to the right side. Is this normal? I was parked on a fairly flat surface too. What should I have looked at? Leaf springs themselves? Bushings?
  2. Mar 20, 2011 at 5:01 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    and when u say right side do you mean drivers side???
    if so its the taco lean.....
    and the creak is the rear leaf pack......
    welcome to toyo land
  3. Mar 20, 2011 at 5:03 AM
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
    I had a similar creek. Took it into the dealer, showed it to him by pushing down on the R-R corner of the truck a couple times. They know immediately what it was - the spring silencer pad. Since it was replaced last Summer, no more noise. There's a scan of the work order in my photos if you want the part number, etc.
  4. Mar 20, 2011 at 5:12 AM
    Chainsmoker
    Chainsmoker Well-Known Member
    Ed
    Phila.PA
    09 Tacoma 4x4 double cab Short Bed
    3inch ProComp Lift. 285/70/17 on ATX Crawl wheels. tinted windows. blacked out tail lights. 8k hid fogs. projector headlights with dual halo rings and 8k hid. remote start. blacked out grille.
    M truck has these same issues. The driver side of the bed is about a half inch higher then the pasenger side, no big deal it not real noticable but i didnt notice it until i did my lift. And the creek in the leaf springs is caused buy seperation in the leafs also no big deal but if it bothers you its an easy fix. there is supposed to be a small rubber pad on both ends of every leaf and sometime they rub through or if you have an AAL the new leaf does not have this pad
  5. Mar 20, 2011 at 5:13 AM
    Chainsmoker
    Ed
    Phila.PA
    Also, Welcome to TW
  6. Mar 20, 2011 at 9:52 PM
    USNavyTaco
    Goose Creek SC
    It leans to the passenger side.
    Also, it has the 3 leaf pack. Apparently the truck never had that TSB done to get the 4 leaf pack. Should i push for the dealer to replace it? Or just have them look at it, and evaluate it from there? I just dont wanna sound like a jerk since the reason ill be returning to the dealer in the first place is to have that stupid blower motor replaced and silencer kit installed.
  7. Mar 21, 2011 at 4:03 AM
    Chainsmoker
    Ed
    Phila.PA
    If i was you, the blower motor would be a must fix that would driver me CRAZY. but the creek doesn't really bother me but if its already at the dealer the tell them to look at it and see what they can do......
    I'm guessing you just got the truck.... and i am guessing you paid good money for that truck from a dealer ....... so get them to fix it... i would
    :thumbsup:... good luck
  8. Mar 21, 2011 at 4:16 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Toytec spacer for driver's side will fix it.............
    3 yr/36000 mile warranty on the leafs. Time for these...........
  9. Mar 21, 2011 at 4:45 AM
    USNavyTaco
    Goose Creek SC
    Yes. I paid good money for it. And its certified used. Which obviously makes that even more expensive. I purchased an extended warranty so I'm trying to have everything fixed that can go wrong before my warranty expires. I've just been reading all these tsb's and am starting to get worried. This is my current list of things to replace. So should I bother with the rear leafs? And if so, how do I get my dealer to replace em? I haven't towed or hauled anything over 500 pounds. So there will not be marks on the bump stops.
  10. Mar 21, 2011 at 6:32 AM
    Chainsmoker
    Ed
    Phila.PA
    just take in to the dealer and tell them whats going on with the truck. should take care of it with no big issues. also just so you know all these TSB's do not go with every truck its just little odds and ends over the past 5 years or so and most can be fixed with help from all of us here on TW and most are very simple fixes. dont worry you will love the taco
  11. Mar 21, 2011 at 8:18 AM
    USNavyTaco
    Goose Creek SC
    Only thing weird it's doing is creaking whenever a person enters or exits the truck, shuts a door, or pushes down on bed. I just wondering if i should push the dealer to give me the 4 pack leaf springs.
  12. Mar 21, 2011 at 8:28 AM
    Chainsmoker
    Ed
    Phila.PA
    My truck does the exact same thing as your describing. The leafs make a creaking noise. Since I have a AAL I know the dealer will not fix it but it doesn't bother me since I know what it is and why it does it.
  13. Mar 21, 2011 at 8:41 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    3 yr/36000 mile warranty on the leafs. 2006 model truck = not free.
  14. Mar 21, 2011 at 8:45 AM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    You can do the leaves yourself, there's a write up on here. Basically need to jack the back by the frame then pry the springs apart some. Now clean and insert cut up old oil cans or bicycle tubes or some other plastic/rubber for rub protection.
    The squeaky leaves won't hurt anything but it's super cool to freshly wash and shine the truck then go park the newest lowest mileage vehicle you've ever had somewhere and hop out to the soundtrack of some old rusty farm truck POS.
  15. Mar 21, 2011 at 10:48 AM
    USNavyTaco
    Goose Creek SC
    Even if I bought an extended platinum warranty? That covers suspension components?
  16. Mar 21, 2011 at 10:18 PM
    USNavyTaco
    Goose Creek SC
    **Update** called dealer. Told appointment secretary I was bottoming out when carrying a load that wasn't even near the capacity. Also that leaf springs were creaking. I'll print a copy of the leaf spring tsb and leave it on the dash when I drop it off. I'm hoping that it's covered under my platinum warranty, especially since it was a certified used. Those of you who have had it done, how likely is it that they will do the tsb? Do I have to fight for it?
  17. Mar 21, 2011 at 11:19 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You'll have to fight, most likely. I fought and fought, even got Toyota corporate involved, to no avail. However, it really depends on the dealer. You're out of warranty but I don't know how it works with Certified.
    Oh, and I have the creak too.
  18. Mar 22, 2011 at 1:57 PM
    USNavyTaco
    Goose Creek SC
    So if they won't install it. Should I just let it go? I am pretty sure they will atleast fix the creak. I just want the 4 pack springs that everyone is raving about.
  19. Mar 22, 2011 at 3:03 PM
    Chainsmoker
    Ed
    Phila.PA
    i have a 3inch lift and put an AAL in the rear
  20. Mar 22, 2011 at 3:11 PM
    USNavyTaco
    Goose Creek SC
    True. If they won't do it I'll put an aal in probably next summer sometime. Not a huge concern since I rarely load the bed with more than 400 pounds. Biggest thing the bed sees is lots of wood. And the occasional mulch bags. I'm gonna focus more on them doing the stupid blower. But unfortunately the sound kit is backordered. Thanks anyway
