Truck Lean "only" after TSB
Discussion in 'Suspension' started by TacoSter, Apr 10, 2009.
  1. Apr 10, 2009 at 2:52 PM
    TacoSter
    TacoSter [OP] Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    I've read where Tacos have up to a 1/2" lean on the drivers side. Mine was perfectly level (side to side) before the TSB.
    Now it measures 3/4" high on the passenger side in the rear... the front is still level.
    Is it possible they installed the darn things wrong? Is this normal? Could this happen if they did not center the spring correct? Just looking for feed back before I call the dealer & make them fix it... Thanks!
    Sorry about another tsb thread, but looked thru 200 plus threads that a search came up with and did not see this
  2. Apr 10, 2009 at 3:09 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    That's not acceptable, get them to look at it.
    Or, get yourself some fat friends and sit them in the passenger side.
  3. Apr 10, 2009 at 3:13 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    How full was your gas tank when you first measured it?
  4. Apr 10, 2009 at 3:15 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    Mine leans higher on the passenger side about half an inch in the front.
  5. Apr 10, 2009 at 4:00 PM
    TacoSter
    Chicago Burbs
    Full both times... I have checked at 1/3 tank and it made no difference. I do have a leer top.. not sure if that matters, but again- this only happened after tsb
  6. Apr 10, 2009 at 4:01 PM
    TacoSter
    Chicago Burbs
    I'm no expert, but what I read about this... some put in a spacer to raise the drivers side... others have swapped springs as they are 2 different sizes and someone most likely installed the wrong side on yours
  7. Apr 10, 2009 at 5:05 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    make sure they installed 4 leaf packs on both sides. have heard of a dealer installing a 3 on one side and a 4 on the other
  8. Apr 10, 2009 at 5:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Check the TSB and the part numbers on the springs- Make sure they were installed on the correct sides....
  9. Apr 12, 2009 at 8:16 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Mine sit DEAD level.
  10. Apr 13, 2009 at 4:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Mine sat level when the springs were new....and even after 1.5 years, the springs have settled and they still sit level (even with or without a full tank of gas).
    Take it back to the dealer and have them fix it
