truck leans toward passsenger side?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98fourbangertaco, Jul 22, 2011.
  1. Jul 22, 2011 at 6:44 AM
    98fourbangertaco
    98fourbangertaco [OP] Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    i have reasently noticed that the rear of my truck is very very slightly leaning toward the passenger side, im assuming this means that my leafs are warn out? anybody else have the same issue?
  2. Jul 22, 2011 at 10:29 AM
    scocar
    scocar hypotenoper
    Common issue. I suggest searching for "Taco lean" and read up to your heart's content. All the heavy stuff is on the driver side. You, battery, gas tank. :)
  3. Jul 22, 2011 at 10:30 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    But his is leaning the OTHER other way. Not the taco lean way.
  4. Jul 22, 2011 at 10:33 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah that's odd I'm leaning towards the driver side. your passenger side leaf pack must be shot.
  5. Jul 22, 2011 at 11:00 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I suggest you inspect the rear end out very carefully on both sides, especially the shackles, I'm assuming that was part of your lift from what I know of Daystar. Look for anything worn or damaged. While looking at it have someone shake or move the vehicle up, down and sideways. On a level surface bounce the rear end up and down several times and let it settle then measure from the ground surface to the fender well across the center of the wheel. Measure both sides to see what the difference is, normally they should be within 1/16 inch +/- with the driver side the lowest and it will depend on how full your gas tank is. You may very well have a weak leaf spring set.
  6. Jul 22, 2011 at 11:03 AM
    johnson910413
    johnson910413 Well-Known Member
    Samuel
    South Carolina
    2011 MGM DC TRD Offroad
    10% Tint, Bull bar, Silver star ultra's, LED Dome Light, ARE Tonneao cover, Two 10" subs, 1000w amp, Exhaust tip. Weather tech mats <3
    I have seen this before !!! do you like to drive around looking for the BBW's cause that will do it
  7. Jul 22, 2011 at 11:08 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    :rofl:
  8. Jul 22, 2011 at 11:08 AM
    scocar
    scocar hypotenoper
    Ooops, well I'm a douche for misreading your post. I missed the passenger part. I'll STFU now.
    How long has the shackle lift been on? They prematurely wear out leafs, from what I understand.
  9. Jul 22, 2011 at 11:14 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Quoted for sig extraction later
  10. Jul 22, 2011 at 12:00 PM
    scocar
    scocar hypotenoper
    Ditto.
  11. Jul 22, 2011 at 12:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Time to bulk up.
  12. Jul 22, 2011 at 2:49 PM
    98fourbangertaco
    Taylorsville, NC
    well i figured it was a warn out passenger leaf but stangly enough it has leveled back out? i know it sounds really weird but i flexed it out to that side to the max on the rear on a mulch pile i was using as a ramp and then noticed it afterwards, i guess it just needed to settle who knows but its level now :) haha and bbw was deff not the the problem!!!!!!!
  13. Jul 23, 2011 at 7:41 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    Mine leans on the right also but it doesnt bother me cause it probably evens out when i get in.
  14. Jul 24, 2011 at 3:00 PM
    98fourbangertaco
    Taylorsville, NC
    its really weird it seems to set perfectly level now
