Truck pulls right when pressing brakes....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BImike, May 24, 2010.
  1. May 24, 2010 at 4:42 PM
    BImike
    BImike [OP] Member
    I noticed my truck pulling right severly when depressing the brake pedal heavily the other day. Feels like the right front brakes are locking or something. It seems to happen when traveling on a bumpy road or off roading.
    This doesn't happen anyother time but when press the pedal hard and it is an uneven surface or off roading.
    Any advice?
    Thanks
    O6 Tacoma, 4 dr., TRD, 4X$
  2. May 24, 2010 at 5:00 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    On dirt or loose surface do you notice any one wheel locking up or skidding more than the others? One thing you should check is the adjustment of the rears. Sometimes they can get out when one side quits adjusting or over adjusts. Have you had brake work done lately? How many miles do you have?
  3. May 24, 2010 at 5:06 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Lots of reasons but it boils down to this, you have more friction on one side then another. Rotor warpage, oil on the pads, water on the pads, uneven wear, leak in brake line, etc. Take off the wheels and look for fluid leaking and pad wear. Spin the rotor by hand and notice if it pulls away from the pad at a certain location. Alignment and mechanical breakage can affect it also but usually not as common.
    Brake pads are cheap and easy to the DIY guy. It would be worth doing that before taking it to a mechanic.
  4. May 24, 2010 at 6:01 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I'd start with the most simple possibility, check the tire pressure. If one tire is at a noticably lower pressure that may be your problem. If both fronts tires are at the same pressure then it's time to check the brakes, then aligment.
  5. May 25, 2010 at 11:09 AM
    BImike
    BImike [OP] Member
    Thanks to all for your help. No oil leakage or water, brake pads are fine...had a friend, who worked at toyota a while back, check the pads and spin the tires with no definite problem. The truck has about 50,000 miles. Tire pressure is fine.
    The alignment is a little off, pulling to the left but nothing major. Gonna' try aligning and see what happens. Another friend mentioned it might be air in the front, right brake line. Hope aligning works.
