Truck shakes when braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18' TACO TRD, Oct 17, 2018.
  1. Oct 17, 2018 at 10:00 AM
    18' TACO TRD
    18' TACO TRD [OP] Well-Known Member
    Florida
    2018 TRD Cement
    I'm getting a shaking/bumpy feeling in the truck when I'm braking from 40-60 mph mostly. It doesn't happen all the time. Maybe certain road conditions play a factor.
    What are some common things to check? Rotor or drums? Lug nuts possibly torqued to much?
    Truck has only 3,500 miles...
  2. Oct 17, 2018 at 10:07 AM
    Himjo
    Himjo Active Member
    Jim
    Oklahoma
    2022 SR5 4WD DCSB - White
    Rotors are likely the most common. How many miles are on the truck? If it is the rotors, you should be able to get them turned rather cheaply.
    ETA: I see your mileage now. Odd with so few miles.
    Rob Daman likes this.
  3. Oct 17, 2018 at 10:36 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Sounds like rotors to me. Were you extra careful not to brake hard during the first few hundred miles? Maybe you can get it covered by a dealer if you ask nicely. How many miles were on your truck when you got it?
  4. Oct 17, 2018 at 11:05 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I'd say rotors like the other guys. Dealer should be able to shave em under warranty.
  5. Oct 17, 2018 at 11:09 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
  6. Oct 17, 2018 at 11:44 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Rotors or possible pads. May be tires so at least check they are same pressure and you don’t have any unbalanced tires. Common manufacturing issues on rotors so get them turned and you’ll be golden.
  7. Oct 17, 2018 at 11:44 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My 18 had the exact same issue at the exact same mileage. Mine were the rear drums. They said they were too tight, they adjusted them and it's much better.
    There's also the possibility of a warped axle. I thought that could have been my issue. I guess I'll know if it returns.
    Bridge4 likes this.
  8. Oct 17, 2018 at 11:58 AM
    18' TACO TRD
    Florida
    2018 TRD Cement
    Interesting. What do you mean to tight? What did they adjust exactly?
    They just replaced my driveshaft (binding), rear leaf springs (pinion angle was off), rear axles (axle flange and drum brake had excessive clearance). I'm not sure if the drums were replaced.
  9. Oct 17, 2018 at 12:27 PM
    toyotatacomaTRD
    I'm not sure. I had two things going on. My brakes and my hood adhesive was missing. When they picked me up in the service shuttle I was expecting to go back to the dealership to pick it up and ask questions, but we actually picked my truck up at a 3rd party body shop who added the hood adhesive. I actually never got to see them, but when he set up the shuttle on the phone, I asked and he said the rear brakes were too tight, so they adjusted them. That was about a month ago. It's been smooth as butter since then.
  10. Oct 18, 2018 at 2:39 PM
    Marconis
    Marconis Well-Known Member
    New York
    2017 SR5 DCSB 4X4
    I had my rear axle replaced, like you, as I was having similar issues. The problem did not go away; they just replaced my rear drums and resurfaced the front rotors for excessive runout. I haven't driven it enough to see if it's gone away, but the braking does feel much better.
  11. Oct 19, 2018 at 7:15 AM
    Nunya Bizness
    Hood adhesive? What are you referring to for the less than average smarts people like myself.
  12. Oct 19, 2018 at 7:17 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The body glue that hold the skin of the hood to the skeleton of the hood
    Nunya Bizness[QUOTED] likes this.
  13. Oct 19, 2018 at 7:18 AM
    toyotatacomaTRD
    There is adhesive that goes between the braces and the actual hood from underneath. It's easy to tell if it's not properly adhered. When you are washing the truck, instead if it feeling solid, it indents. You can also look underneath. The adhesive on mine was separated from the very beginning. They added, now it's nice and solid.
  14. Oct 19, 2018 at 7:32 AM
    Nunya Bizness
    Oh okay that makes sense. Thanks for the information
  15. Oct 19, 2018 at 7:40 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Do you have a dial indicator to check rotor runout?
    Jack up the rear (both sides) and spin the wheel. There should be slight resistance; too much and you need to adjust the brake shoes.
    Ultimately though at this point in the truck’s life, even if it’s an easy fix you should take it to the dealer so it’s documented in case you have issues later.
  16. Oct 22, 2018 at 9:28 AM
    18' TACO TRD
    Florida
    2018 TRD Cement
    Its at the dealership now. They had it all day Saturday and need it longer. I guess they have another TRD sport next to mine and swapping out and comparing parts.
    I have them looking at the rear drums, driveshaft. They also did an alignment bc it was a little from when I first got it. It has only 3,900 miles on it.
    My last visit they replaced - driveshaft, rear axles and rear leaf springs.
  17. Oct 22, 2018 at 9:29 AM
    Marconis
    New York
    2017 SR5 DCSB 4X4
    Good luck.
  18. Oct 27, 2018 at 5:57 AM
    garner2002
    garner2002 Well-Known Member
    DFW TX
    2018 TRD Pro Cavalry Blue
    https://www.tacomaworld.com/threads/2018-dcsb-or-brake-shudder-stutter.574419/#post-19009979
  19. Oct 27, 2018 at 6:02 AM
    Marconis
    New York
    2017 SR5 DCSB 4X4
  20. Oct 27, 2018 at 6:32 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is shaking proportional to braking pressure? Shaking stops if you let off the brake?
    Would you describe the shaking like "running over a rumble strip"?
