truck slams on bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by simontorres38, Feb 22, 2019.
  1. Feb 22, 2019 at 7:15 PM
    simontorres38
    simontorres38 [OP] Active Member
    Simon
    2012 Black Tacoma sr5
    so i have the bilstein 5100 rear shocks (intsalled 6 months ago) on stock leafs springs and a 1'" inch block, when im on the trails and go over bumps my rear end just slams hard after going over bumps
    what would be a quick fix for this? i was thinking of installing the emu dakar leafs hoping this would solve the issue ... what do you guys think?
  2. Feb 22, 2019 at 7:18 PM
    eon_blue
    Azusa, CA
    Yes, Dakars will help...blocks are notorious for making the ride harsh. Get the Dakars for the rear lift and ditch the blocks
    TacoCasa and Heath75 like this.
  3. Feb 22, 2019 at 7:22 PM
    ktmrdr
    ktmrdr Well-Known Member
    And add some super bumps....
  4. Feb 22, 2019 at 7:23 PM
    simontorres38
    Simon
    @ktmrdr thanks bro im just trying to get a smooth ride and not spend money in vain
    ktmrdr likes this.
  5. Feb 22, 2019 at 7:29 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Take it to the dealer and get the recall done, then buy a progressive aal before the new leafpack shits itself. Thats if u dont wanna spend for dakars.
    Superbumps are a band-aid not a fix right?
  6. Feb 22, 2019 at 7:32 PM
    eon_blue
    Azusa, CA
    I wouldn't call them a band aid but they shouldn't be used in lieu of having the right rear setup. Ditching those blocks should be his #1 priority
  7. Feb 22, 2019 at 7:42 PM
    inwood customs
    Dave
    They do make a great addition, agreed.
    The stock leafpack is shit, blocks accelerate de arching, stock bumps dont forgive.
    eon_blue[QUOTED] likes this.
  8. Feb 22, 2019 at 7:54 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Spring rate is too light. Bump stops are limiters (end of travel) and shouldn't be a regular occurence since those shocks are transmitted to the axle and bearings which the springs are supposed to protect. Too high a spring rate is just as bad since the springs won't travel enough to soften hits either. Either correct the spring rate with an aal or new pack or slow down enough to ease over the larger hits. If it happens on the road too then you definitely need better springs. Sumo springs are more for occasional extra loading as a less expensive and simpler alternative to a variable spring rate system like air bags.
  9. Feb 23, 2019 at 3:50 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Before I'd go spending any more money, I'd be looking at the rear suspension - specifically the rear shocks - to see if anything's loose. I've seen shocks installed incorrectly and end up banging around in their mounts. And since the OP has added blocks, I'd be checking U-bolts too. Just a thought.
    Clearwater Bill likes this.
  10. Feb 23, 2019 at 6:13 AM
    DirtTaco
    DirtTaco Well-Known Member
    Have you checked to see if your front right bed mount screw looks like it’s raised up at all? I just had to pull the screw out and sandwhich a chunk of rubber between where the bed contacts the frame. The composite bed mounts wear out causing a gap and when the bed bounces up and down it’s loud AF. Only happens going over bumps.
    Muddinfun and WSW3 like this.
  11. Feb 25, 2019 at 5:41 PM
    08RC
    08RC Well-Known Member
    I have the TSB rear springs and a 1" lift block. Never heard of a 1" Block causing a rough ride before now. Sure 100% springs would be better but in reality it depends on what you are after whether it's worth the cost for the end result you are looking for. Many trucks came with much taller than a 1"block as OE and were never blamed for a harsh ride. Before I installed my Fox shocks and after I removed the existing shocks I bounced the rear up and down by hand. That thing moved easily and my TSB springs are not the cause of a harsh ride. They support the weight for the most part. If you have a rough ride in the rear you can blame the shocks and the air pressure in the tires more than springs . If Bilstein makes the 5100's for these trucks anything like they do for Jeep Wrangler or Ram's they are pretty much the reason for the rough ride. I have had them on more Jeeps and Rams than I care to admit and usually they were replaced by something else when I could afford it and the ride improved. For the most part with shocks you tend to get what you pay for .
  12. Feb 25, 2019 at 5:47 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Can you unbolt the top of one of your rear shocks? I'd do this, jack the back end up placing the jack under the rear diff, put jack stands under the frame and slowly let the jack down. If the side with the unbolted shock drops significantly more than the side with the shock still attached, you might be hitting the end of your travel with the shocks and getting some jarring with that. IF that's the case, you can install Toytech shock extenders on the top of each shock.
    Just a thought.....
  13. Feb 25, 2019 at 6:29 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    What air pressure do you run in the tires?
  14. Feb 25, 2019 at 6:35 PM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    Wheelers super bumps, night and day difference. Even with an AAL or dakars you will still sometimes hit the bump stops and the factory bump stops are bricks.
  15. Feb 25, 2019 at 6:47 PM
    simontorres38
    Simon
  16. Feb 25, 2019 at 6:47 PM
    eon_blue
    Azusa, CA
    Same for the front bumps, upgrading those was a big improvement for me even with Kings up front
    simontorres38[OP] likes this.
  17. Feb 25, 2019 at 9:19 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Well it shouldn't that causing it to ride rough.
  18. Feb 26, 2019 at 4:36 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Take the blocks out. Problem solved.
  19. Feb 26, 2019 at 4:49 AM
    Clearwater Bill
    Billy
    Largo Florida
