Truck spray painted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rashnu, Nov 26, 2010.
  1. Nov 26, 2010 at 3:14 PM
    Rashnu
    Rashnu [OP] Well-Known Member
    '16 T4R TEP
    Stock
    So my 09 taco was spray painted in the ealry morning hours of thanksgiving? Any suggestions on how to get it off?
  2. Nov 26, 2010 at 3:16 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Car polish (maguires) will remove spray paint! Or you can use alchohol for the rubber trim.
  3. Nov 26, 2010 at 3:16 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    sandpaper...
  4. Nov 26, 2010 at 3:20 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Insurance company...
  5. Nov 26, 2010 at 3:42 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Here's what I'd do in order...
    1. Quickly try wax (or a polish like Zaino)
    2. Try clay bar and soapy water
    3. Try very light rubbing compound
    4. Try medium duty rubbing compound (press lightly)
    If you use ANY rubbing compound, don't press hard and follow up with wax or polish afterwards to remove any clear coat scratches.
  6. Nov 26, 2010 at 3:58 PM
    toojayz
    toojayz Well-Known Member
    Jim
    Northern NJ
    2011 TRD Sport 4x4 DC MGM SB
    Easy off oven cleaner will take it right off. Trust me, I used to detail cars
  7. Nov 26, 2010 at 4:02 PM
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    likewise
    sorry to hear man that sucks
  8. Nov 26, 2010 at 4:19 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I'd try some goo gone, then maybe some nail polish remover, there's non acetone and acetone based stuff, try the non acetone first. Modellers use the non acetone based stuff to remove painted on writing and stuff without harming the finish underneath. I know goo gone has worked real well on overspray for me in the past.
    It'll be a little slow but it's better than using something super harsh and taking the truck's paint off too. Maybe use a microfiber rag and preferably a garage or at least a shady spot so the stuff has some time to work before it dries off.
    What's working in your favor is the truck paint is well and full cured and applied to a prepped substrate and then there should be a wax layer between that and the spray paint. My best advice would be start with something real gentle like above then slowly work your way up to harsher methods if these don't work. Do not use a paint stripper and I'd avoid any kind of sandpaper, it's way too easy to wreck the finish on the truck. Here in town once one of the auto parts guys told a customer to use aircraft paint stripper to remove some pinstripes and the poor customer listened then proceeded to remove the paint right to the metal from headlight to taillight.
    Whatever you try though first try it in a hidden area like under the front valance or something and make sure it doesn't damage the truck paint. Oh, and once you get it off you'll want to rewax.
  9. Nov 26, 2010 at 5:14 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    You can try prep sol, it is available from any paint jobber. (always try a small unnoticable spot first)
    A body shop or detail shop should be able to point you in the right direction.
    Calling your insurance company would be a last resort depending on your what comrehensive deductible is.
  10. Nov 26, 2010 at 9:38 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Goof Off on a small terry shop towel. What ex girlfriend did it?
    RZ Rob.
  11. Nov 26, 2010 at 9:46 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    I would go this route first also. That sucks man, sorry to hear about that.
  12. Nov 26, 2010 at 9:48 PM
    TacoMal
    California
    Or just get it really muddy and leave it that way... :mudding:
  13. Nov 26, 2010 at 10:04 PM
    JTanner
    JTanner Misplaced Texan
    Temecula, CA
    09 DC TRD OR MGM
    stock..for now
    Pics! (sorry, we post them for everything else...why not this). Sorry it happened though. That sucks.
  14. Nov 26, 2010 at 10:08 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    someone spray painted my wife's GTI a few years ago. they hit a small parking lot in front of a pretty busy business.
    you can try mineral spirits for the paint and prepsol for the trim. neither will hurt anything.
    at any rate, it's definitely not the end of the world, any competent professional detailer will be able to get it off. call around and see who has experience with such vandalism removal.
  15. Nov 26, 2010 at 10:11 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    acetone works well but you have to act fast and dont keep it on the truck for more than a few seconds to minimize effect on clearcoat and trim pieces
  16. Nov 26, 2010 at 10:12 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    yeah try insurance
  17. Nov 26, 2010 at 10:13 PM
    rcfreak201
    rcfreak201 Well-Known Member
    :worthless:
    show us pics of the spraypainted part!
  18. Nov 26, 2010 at 10:13 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    my stupid brother got spray paint on my 02 taco before, 2 clay bars a few micro fiber towels and time will do you well, also use those lil pads you apply wax with to get it off and finger nails
  19. Nov 26, 2010 at 10:16 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  20. Nov 26, 2010 at 10:29 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    another vote for claybar, my stepdads car got green overspray from painting our buildings all over it, claybar took it right off with some elbow grease
