Truck Stalls: Reverse to Drive
Discussion in 'Technical Chat' started by RELLIM, Jun 30, 2012.
  1. Jun 30, 2012 at 10:59 PM
    RELLIM
    RELLIM [OP] Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    Anyone ever had a problem on a 2010 or newer with stalling?
    I've found out that when i shift from reverse to drive quickly without coming to a complete stop, the engine stalls..
    Is this just a safety thing? and its made to do this or is this a real problem?
    I'm guessing this isn't the good old days where you can shift from rev to drive in one motion.
    Can someone confirm this theory?
    thanks...
    rellim
  2. Jun 30, 2012 at 11:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Stalls the motor ( rpms plummet ) or the acceleration seems delayed ?
  3. Jun 30, 2012 at 11:08 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    mine never does that and i shift pretty quickly from drive to reverse and vice versa, sometimes the truck is still rolling a bit when i shift it into either drive or reverse, and never a problem. is your linkage fucked up? there has to be a way to adjust it.
  4. Jul 1, 2012 at 6:17 AM
    RELLIM
    IOWA CITY IA
    It kills the engine, Its happen a couple of times.
    When it happens i press the brake and throw it back lnto
    Park and she fires and i go (pissed of course).
    I had turned vsc off before any of this took place, so it was
    A open rear end . It has happen with the vsc on.
    I do like bang gears alot, wish they had the auto stick
    Option for my tranny.
    So... Something may be loose .
    I poke around underneath when i get the chance ...
  5. Jul 1, 2012 at 8:52 AM
    OZ-T
    Peter North
    British Columbia
    I've noticed a throttle lag in my auto sometimes when switching from reverse to D , but not to the point that it kills the engine as you describe
  6. Jul 1, 2012 at 10:12 AM
    RELLIM
    IOWA CITY IA
    Will the vin number tell me what exact transmission i have on my truck?
    Or is there a place on the tranny case that will tell me what tranny i have.
    I've got problems with the tranny slipping while its in park and on a hill.
    wondering if the manual tell me when i need to use my e-brake on what grade of slope.
    I also saw there was some new flash for the ecm for the tranny, is this correct?
  7. Jul 1, 2012 at 10:13 AM
    OZ-T
    Peter North
    British Columbia
    The tranny TSB reflash was for pre-2010 trucks
