Truck stuttering...help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by LarrysWorld, Feb 27, 2012.
  1. Feb 27, 2012 at 9:29 AM
    LarrysWorld
    LarrysWorld [OP] 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    So my truck has been stuttering and i changed the TPS sensor because a code came up for that and the ride was fine. but then it came back and checked my spark plugs and i guess i have the wrong the plugs in. but now one of the wires that connects to the spark plugs is burnt but still runs.. could that be why its still stuterring??:confused:
    plus idk haow to change that wire... if anyone can help i would appreciate it.
  2. Feb 27, 2012 at 9:48 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Ya it's probably arcing to the block. .
    How exactly does it "stutter"-upon a load..at a certain RPM...all the time...etc? To check for arcing run the engine hood up and listen for a 'tick' in time with the miss-if the tick is coming from that burnt wire area there ya go.
  3. Feb 27, 2012 at 9:55 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
  4. Feb 27, 2012 at 10:00 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You don't want the plug wires touching anything HOT; thats for sure. images_f2ab5c85f453aa0abf3634a42a762909984b791f.jpg
  5. Feb 29, 2012 at 9:19 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    could that be why its stuttering?
    what kind of tool can i use to take out the spark plug? because the wire ripped and its stuck to the spark plug.
  6. Feb 29, 2012 at 9:24 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    A burn through is a sure sign of a failed wire and misfire. Replace ALL of the plug wires.
  7. Feb 29, 2012 at 9:25 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If the boot is still on the plug, a long pair of needlenose pliars will be needed to remove the boot.
  8. Feb 29, 2012 at 9:25 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Get a pair of needle nose pliers and get the boot/wire piece off of the plug. Then standard plug socket with ratchet to take the plug out.
    Not sure what "plug wrong" means, but probably fouled if the spark on the wire has been arcing to ground on the engine. This would cause the truck to run rough as that cylinder would now be firing correctly.
  9. Feb 29, 2012 at 9:30 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    sparkplugs.jpg i have similar ones to these and they said i need ones that have two curves instead of one if that makes any sense.
  10. Feb 29, 2012 at 9:30 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    alright man thanks for the help, hope that works because my mpg if shit right now.
  11. Feb 29, 2012 at 9:35 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Misfires have the capacity to break things, if severe enough.
    They do make spark plug boot pliars. They have a boot shaped tool end.
  12. Feb 29, 2012 at 9:42 AM
    Hillingdoner
    Rio Rancho, NM
    Get the factory Denso plugs for it. They have the correct ends you need and work well.
    Wires wise replace your wires and be sure to run them as per factory and away from heat sources. When removing wires never pull on the wire itself to remove. This will often cause wires to come apart. Remove the wires by the boot. I like to give them a little twist to ensure they are loose before removing.
  13. Feb 29, 2012 at 9:48 AM
    Hillingdoner
    Rio Rancho, NM
    Finally found the link again. Been searching for it for another poster with a misfire.
    Here is the link for the ignition system. Shows you how to route the wires and how to remove the plug wires from the plugs. I believe it also gives you the plug number you need I'd have to look again.
    Anyway, hope it helps.
  14. Feb 29, 2012 at 9:53 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  15. Mar 1, 2012 at 6:14 AM
    Hillingdoner
    Rio Rancho, NM
    OP- Did you get your plugs and wires replaced? Cure the issue?
  16. Mar 1, 2012 at 8:01 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    I replaced the spark plugs but they gave me the wrong ones and I've never replaced the wires.
  17. Mar 12, 2012 at 9:28 AM
    LarrysWorld
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    So ive replace the spark plugs with the correct ones and changed all the spark plug wires but its still stuttering.
    feels like my rpms drop and then raise again making my truck to want to turn off. it also jolts my engine and it feels really bad.
    any ideas of what it can be now?
  18. Mar 12, 2012 at 6:15 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Spray a water mist on the coil and look for arcs(in the dark). If no arcs. Start looking at fuel injectors. Have you Seafoamed lately?
  19. Mar 12, 2012 at 7:03 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Is your truck throwing any codes?
    It sounds like one of the three spark plug power modules (that your spark plugs plug into). My buddy's 2.7L had one of those go bad and it did the same exact thing.
    On the 3.4 they are located on the passenger side of the engine and the spark plug wires from the driver's side plug into them if I recall correctly. I would go look, but my truck is still at the body shop.
  20. Mar 13, 2012 at 4:17 AM
    crainholio
    crainholio Well-Known Member
    Is this another way of saying "ignition coil"?
