Truck will only start with jump start and only sometimes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Makana’floatum/ramble, Oct 28, 2024.
  1. Oct 28, 2024 at 5:34 PM
    Makana’floatum/ramble [OP] Member
    Makana
    White 99 Tacoma 5vz fe
    Recently my truck wouldn’t start so I got a new battery and then a new alternator, the truck started but then the next morning it wouldn’t start. I tested the battery with a multimeter and it was reading 12.8 volts so it should’ve been able to start, as well the dash lights won’t even come on unless I have a jumper pack connected, I did a continuity test and everything was fine there is also a weird clicking noise that randomly happens if i have the key turned in the run position but it happens randomly not all the time . I checked all the grounds to and they looked well, I’m really lost right now what could be wrong.
  2. Oct 29, 2024 at 8:40 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ugh
    I know this “intermittent” problem well
    after years I finally determined (from a GTO forum no less)was a ground issue for my vehicle
    I know I know….all grounds good u said
    (Exactly what I said for a LONG time)
    GL
  3. Oct 29, 2024 at 9:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Does it sound like this?
    You can fix it cheap.
  4. Oct 29, 2024 at 10:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the dash lights don’t come, I don’t think it’s a starter issues.
    You have a power or ground issue.
    Have you inspected the battery cables really good?
    They can corrode inside the sheathing.
    The key detail here is “no dash lights unless jumper is connected…..
    You may even have an ignition switch issue?
    loudboy likes this.
  5. Oct 29, 2024 at 10:09 PM
    TnShooter
    Deogee
    STOCK
    When this happens, do the brake lights work?
    What about the head lights?
    We need to see where the power failure is.
