Truck with 3.4 randomly died while idling at stop sign???
Discussion in '1st Gen. Tacomas (1995-2004)' started by NotstockTRD, Aug 12, 2009.
  1. Aug 12, 2009 at 7:31 PM
    NotstockTRD
    NotstockTRD [OP] TRD
    st louis
    99 TRD Prerunner V6 with many mods..
    Shitloads
    A few weeks back I was at a stop sign and my truck idle shuddered and almost died(rpms dropped out of nowhere).. I was thinking it was just a injector blockage or something anyways drove off and problem went away!
    Yesterday same scenario except it shuddered and died! I put it in park and it fired back up with no problem/hesitation? It did NOT even throw a check engine light?? This obviously is going to happen again soon im asuming..
    I ran seafoam about a month ago and it has been running like a champ up untill these mysterious incidents.. I have 140,000 miles and im thinking it might be my idle air control valve??
    Any suggestions?
    Thanks in advance
    __________________
    TRD
  2. Aug 12, 2009 at 7:36 PM
    NotstockTRD
    st louis
    Shitloads
    any helpfull suggestions?
    thanks..
  3. Aug 12, 2009 at 7:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Give everyone a few mins to think about it, Buddy. :)
    Are all your vacuum lines connected propperly?
  4. Aug 12, 2009 at 7:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe the iac valve needs to be cleaned........and while you do that....maybe change the fuel filter too and clean the tb(cause you'll already be into it with the iac valve).
  5. Aug 12, 2009 at 7:50 PM
    NotstockTRD
    st louis
    Shitloads
    sorry, thanks yeah they are all connected properly
  6. Aug 12, 2009 at 7:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would look into what Tacomaman06 said then. Keep us posted. ;)
  7. Aug 12, 2009 at 7:59 PM
    NotstockTRD
    st louis
    Shitloads
    As far as the IAC valve goes how do u go about cleaning it? does it need to be removed in order to clean? Is it a pain to remove?
  8. Aug 12, 2009 at 7:59 PM
    j_cyrus
    j_cyrus Well-Known Member
    Rickman TN
    I can't help you with your problem, but put up some pics of your truck :D
    a mod list would be nice too :)
  9. Aug 12, 2009 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Aug 12, 2009 at 8:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....not toobad to get to....on the bottom of the throttle body,so you'll need to remove it. you'll need a new iac valve gasket..and new tb gasket.
  11. Aug 12, 2009 at 8:25 PM
    NotstockTRD
    st louis
    Shitloads
    here ya go-
    99' TRD 3.4L V6 Prerunner-
    rollbar with 5"procomp aux lights- customized skid and front bumper trimmed
    3" lift up front 2.5" AAL in rear -NEW bilstein HD's all round'
    2" 4crawler body lift
    -NEW 33x10.50r15 BFG MT KM2's-flowmaster exhaust-deckplate mod- bushwhacker cutout flares -
    factory matched tint/tinted brake lights- cragar soft 8 wheels/mounted with 1/4" wheel spacer-
    -custom Body line down bedliner
    2 boston pro accoustic 12.5 subs in custom box(bolted down)- with boston pro speakers throughout runnin off of 2 alpine v12 amps (not the best when bouncing around off road!)
  12. Aug 12, 2009 at 8:46 PM
    NotstockTRD
    st louis
    Shitloads
    bump for any other advice or opinions?
  13. Aug 12, 2009 at 8:49 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    advice? take off that body lift, and the back to the future bar.
    opinions? murder that bitch out!
  14. Aug 12, 2009 at 9:29 PM
    NotstockTRD
    st louis
    Shitloads
    its all ready murdered out aside from white walls and red skidplate and headlights.. body lift is the shit!! rollbar is awesome too..
    back to subject at hand though any other advice on my engine issue?
  15. Aug 12, 2009 at 9:42 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    It's your Air Idle Control Valve. I had the same problem on mine. I had to replace mine, cleaning it didn't help much.
  16. Aug 12, 2009 at 9:50 PM
    NotstockTRD
    st louis
    Shitloads
    is the general consensus that its better to just replace vs cleaning it?
    Its a $270 part..
    DId you have the exact same symptoms as me? is it easy to replace?
    did it get to the point (dieing)where you had no choice but to replace it?
    thanks
  17. Aug 12, 2009 at 10:12 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    At first it was ok I drove it like that for a week, I would idle at 300-400 then normal, then it got worst, so i tried cleaning it and made no difference. during the second week it would idle at 200-300 when coming to a stop or completely shut off. Or just starting it up it would die, then a restart and it would die, I had to hold the brakes with my left foot and gas with my right, and would drive around like that. I finally got it fixed during week 3. it was 320 for me using OE parts.
  18. Aug 12, 2009 at 10:15 PM
    NotstockTRD
    st louis
    Shitloads
    was it 100% normal after that? what does it idle at now?
  19. Aug 12, 2009 at 10:37 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    sounds like a similar problem i had, stopped, made a right, truck rpms dropped and my truck shut off then turned back on like nothing happened. (alternator problems i think)
  20. Aug 12, 2009 at 10:41 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    It idles normal now, 550ish to 580
