Truck won't let me slide.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BHAGAN, Dec 11, 2014.
  1. Dec 11, 2014 at 7:02 PM
    BHAGAN
    BHAGAN [OP] Member
    Brett
    Littleton NH
    13 baja
    I have a 2013 tacoma baja and i want to slide around in the snow but the truck won't let me. I trun my traction contol of an auto lsd light shows up on my dash as well as a traction control light but if i spin the tires another traction control light blinks and a clicking sound comes from under the dash and the motor kinda dies down. Whats is causing the problem? please help i want to have some winter fun!
  2. Dec 11, 2014 at 7:05 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Hold the traction control button for 8 seconds to turn stability control off. I think it auto turns back on over a certain speed, but see how that works for you :)
  3. Dec 11, 2014 at 7:07 PM
    bigcrab
    bigcrab Well-Known Member
    2014 DCSB 4x4 TRD OR
    ^ This but you have to be stopped to disengage
  4. Dec 11, 2014 at 7:08 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You have to do this. But yeah, it won't completely let you go wild. If the truck thinks you're getting too out of control it will still correct you.
  5. Dec 11, 2014 at 7:10 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  6. Dec 11, 2014 at 7:20 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Had to do this all the time with my 2011 just to drive it in snow, I hate traction control, glad I don't have to worry about it on my 04.
  7. Dec 11, 2014 at 7:23 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Come to a complete stop. Press and hold until the Auto LSD light goes off. You're good until you restart your truck. Unless you do the kill mod.
  8. Dec 11, 2014 at 7:26 PM
    BHAGAN
    BHAGAN [OP] Member
    Brett
    Littleton NH
    13 baja
    Okay thanks for the help ill try it tomorrow!
  9. Dec 11, 2014 at 7:31 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    trade it in for a 1980 F150
  10. Dec 11, 2014 at 7:34 PM
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
  11. Dec 11, 2014 at 7:34 PM
    Chuck Wagon
    Chuck Wagon Well-Known Member
    Grass Valley, CA
    TRD Off Road, Double Cab
    If you have a TRD OR or SR5 it basically leaves you with open diffs, which just spins, but doesn't drift well.
    I found this out screwing around in a parking lot full of leaves a few weeks ago. If I did nothing with any of the traction aids, the truck would correct at the slightest hint of oversteer or traction loss.
    If I hit the button quickly, the Auto LSD comes on, and the traction light. This appears to allow the fishtail like action, but only for a few seconds before the truck auto-corrects itself.
    Holding button for 8-seconds or so, turned the Auto-LSD off, and basically allowed what seemed like generous wheel spin, but it wasn't really letting me drift or slide, since it was just a one wheel peel.
    Seems like when the Auto-LSD is on, you get Posi-like action out back, but the computer won't really let you play in that mode.
  12. Dec 11, 2014 at 7:38 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Most fun you can have whilst rallying gravel roads
  13. Dec 11, 2014 at 7:44 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I have the 2.7l SR5 and if I want the back end to kick it is a very simple task. Come to full stop and push traction button in for a five count, you can start rolling slowly at four and everything will still turn off. At 15 to 20 I push in the clutch, give it gas and let the clutch out smooth but quick. I can grab third if I run wheel speed out to 30's and shift quick. 25 to 30 is the same but third gear and can get fourth if run wheel speed up again. It is all smooth and controllable with practice. I only do it on roads that aren't heavily traveled and not on blind corners. I have been hanging the back end out at 40-45 actual speed at close (within 1/3 to 1/4 turn of wheel) to full lock since last winter. There is no clunking or banging when done on slippery roads.
    ETA: Personally I don't like the A-LSD for fun because it breaks the spinning wheel, which limits acceleration of the wheels. In some situations it allows you to gain speed but not all. The A-LSD does allow you to maintain speed in semi deep snow with wheel spin if you are 2k and above in RPM's, but in deeper snow it will just slow you down and finally bring you to a stop. With a little work you can get back end to kick out on gravel/snow with all traction controls off and accelerate wheel speed to grab another gear. This is with the 2.7l so the 4.0l might be able to gain speed with just A-LSD on.
  14. Dec 11, 2014 at 7:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The truck is trying to prevent you from earning a Darwin Award.
    mahaloTaco likes this.
  15. Dec 11, 2014 at 8:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You didn't trun it off properly OP
  16. Dec 11, 2014 at 8:13 PM
    Traviste
    Travis
    Georgia
    Nothing stops a true competitor
  17. Dec 13, 2014 at 7:35 AM
    danschmatz
    danschmatz Member
    Dan
    Denver
    TRD Off Road
    On my 2015 if I hold the button down for 3 second while it park it will turn traction control off and it stays off till I hit the button again or turn off the truck.
  18. Dec 13, 2014 at 7:52 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Well, yes... to a degree... and the thing the slider wants to turn off is the VSC (which is paired with the traction control in most modes).
    Seriously, one should appreciate having a great vehicle and drive it for years and years, not do stunts with it as if it is a skate board and daddy will buy you another if it breaks.
    Here's how I would describe the button process:
    You don't have to put the tranny in Park, just STOP moving.
    *Press the VSC OFF button (while stopped) and hold it in until the light comes on (~3-5 seconds).
    * Until you press the button again, or restart your truck, the VSC and TRAC will stay off... UNLESS you drive in a dangerous manner!!! In which case the VSC will come back on to prevent you from wrecking your truck.
    Now, the real reason Toyota has that button to turn off VSC is for when you are stuck in snow and need to spin the tires to fling the snow out of the tread when enhanced traction control didn't get you moving (Enhanced in H2: AUTO LSD/ in H4 '12+: TRAC OFF MODE). 2009-2011 H4 is normally in enhanced traction control. 2012+ requires a quick press of the VSC OFF button.
  19. Dec 13, 2014 at 2:22 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    one reason I still have my 08, real LSD and no traction control
  20. Dec 13, 2014 at 2:47 PM
    OZ-T
    Peter North
    British Columbia
    Turn it off and you can slide around in the snow no problem
