Truck won't move in 4x4 with wheels turned
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pbrstaco, May 7, 2011.
  1. May 7, 2011 at 5:17 PM
    pbrstaco
    pbrstaco [OP] New Member
    CT
    Toytec ultimate lift, LR UCA's, Amp Research power steps
    I have a 2010 tacoma 4x4 double cab long bed. After about a 1K miles I installed the toytec ultimate lift with light racing UCA and 1" diff drop spacers. After installing the lift I noticed that when the truck is in H4 the front drive shafts seem to bind to the point that the truck won't move when making sharp turns.....like in a parking lot. It almost feels like you are trying to drive with the parking brake on. If I straighten the wheels out the truck will move again. I didn't try the 4 wheel drive before I added the lift so I don't know if the problem existed before I installed the lift. The truck drives perfect in H2. No alignment issues, no vibrations, great ride. Has any one else experienced this issue with 4 wheel drive?
  2. May 7, 2011 at 5:19 PM
    rizzo20
    rizzo20 Active Member
    Central PA
    TRD Off Road
    Thats perfectly normal.
    **Oh and welcome to TW!!
  3. May 7, 2011 at 5:20 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    yep what he said/\ /\ /\
  4. May 7, 2011 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    DO NOT run 4 wheel drive on dry pavement.
  5. May 7, 2011 at 5:24 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Why do people do this..........
  6. May 7, 2011 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First time owning a 4x4, or comming from an AWD, and just think that you can do it safely. Lots of folks do this.
  7. May 7, 2011 at 5:26 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Might be a good idea to read the owner's manual.....
  8. May 7, 2011 at 5:27 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Welcome to Tacoma World, be sure to ask people here before you do stuff that might tear up your truck. We more and likely have made the mistakes and you can learn from our experiences.
  9. May 7, 2011 at 5:30 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Do NOT ever drive in 4x4 on dry pavement -- especially trying to make sharp turns.
    :facepalm:
  10. May 7, 2011 at 5:30 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Good point ive had trucks since i was old enough to drive lol
  11. May 7, 2011 at 5:37 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Now you know, and knowing is half the battle.
    Yea...I'm wearing a G.I. JOE shirt.
  12. May 7, 2011 at 5:43 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Poor truck
  13. May 7, 2011 at 5:46 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you just gotta floor it!!! itll give...
    J/k
  14. May 7, 2011 at 5:50 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why does Toyota tell you to use 4 wheel drive once a month for 10 miles? Quit snowing here last month.
  15. May 7, 2011 at 5:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    and by "it", you mean the the diff:eek:
  16. May 7, 2011 at 5:53 PM
    jandrews
    '09 FourDubDee TRD OR
    Do NOT use part time 4wd systems on pavement. You will break your truck eventually if you keep doing it. Read this:
    http://www.rubicon-trail.com/4WD101/driveline-bind.html
    Before you ask, no, you didn't kill it just by taking one turn in the parking lot. Keep your ears out for unusual noises and your ass out for unusual vibrations/thunks/grinds/etc., and if you don't have either, you got off without penalty...this time.
    Don't make a habit of it.
    I'm still trying to figure that out myself, because the rationale of lubing everything makes no sense.
    2gen Tacomas have an automatic disconnecting differential 4wd system. This system works in such a manner than the front differential gears are always spinning when the truck is moving. Seeing as the transmission powers the t-case, which powers the rear diff, which powers the rear wheels in 2wd...all portions of the 4wd system that HAVE lube ARE being lubed whenever the truck is rolling, even in 2wd.
    Furthermore, it doesn't take ten miles to rotate everything in a diff through the oil bath. 50 feet would do it.
    My guess is the real reason is to prevent actuators from sticking.
  17. May 7, 2011 at 5:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    to lube up the 4wd system by moving the parts around. You can just throw it in 4hi on a straight section of paved road for a few minutes, just DONT turn on a grippy surface with 4wd activated.
  18. May 7, 2011 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    Engaging 4x4 to lube the system and cranking it to full lock on dry pavement are not the same thing .
  19. May 7, 2011 at 5:57 PM
    pbrstaco
    CT
    Thanks to everyone for the feedback. I did read the owners manual and was performing the 10 mile per month drive in H4 just to keep things lubricated when I pulled into the gas station and experienced this issue. I'll make sure not to do more than drive straight on pavement in 4x4.
    I researched this forum for months before adding my lift kit and UCA's. I found more great info than I could imagine. Awesome forum. Thanks again.
  20. May 7, 2011 at 6:00 PM
    OZ-T
    Peter North
    British Columbia
    FWIW , I think the owner's manual could definitely be a little more clear on this particular point .
