truck wont occasionally won't start
Discussion in 'Technical Chat' started by Constant, Nov 1, 2013.
  1. Nov 1, 2013 at 5:01 PM
    Constant
    Constant [OP] Active Member
    Los Angeles
    06 TRD Offroad X-Cab
    Hey all,
    I've been having a weird problem where my truck won't start at all. When i turn the the ignition, absolutely nothing happens. I don't hear a click, no chugging, its absolutely silent. I know its not the battery (it's clean and no indicator light) because everything turns on, radio, headlights, everything. I usually give it a few tries and nothing happens, but eventually, it'll just start. I'm due for my 60k maintenance, sadly, I haven't gotten around to it yet, but everything coincidentally seems to want to fall apart. Anyone have any ideas?
  2. Nov 1, 2013 at 5:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm gonna guess Ignition Starter Switch. [​IMG]
  3. Nov 2, 2013 at 6:51 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Clean and tighten your electrical and grounding connections between your battery and starter.
  4. Nov 11, 2013 at 3:21 PM
    DogToy02
    DogToy02 New Member
    02 TRD Supercharged
    Ive got the same problem. got to where it wouldnt start at all. I was basically stranded and ended up smacking the ecu with a rock, once. fired right up. havent had a problem since. nobody has a clue what it could be.
  5. Nov 11, 2013 at 3:28 PM
    fuballs
    fuballs Well-Known Member
    Ben
    BC, Canada
    07 Double Cab Long Bed SR5
    Leer Canopy, Thule Roof Rack, Aux Fog Lights, okledlightbars.com 30" double row, AUX fuse Box, Tepui Kukenam
    Test your battery. I had the same problem. Add distiller water if you have the original battery from Toyota and it needs it. Pop the plastic tabs off on the top of the battery and you will see the water line and a mark for where it should be. I had to get a new one it was so fried.
  6. Nov 11, 2013 at 3:33 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Starter contacts==In the starter.
    To Test--leave the key in the start position(when it will not start) Smack the starter with a tool-If it starts--thats the problem.
    Replace the starter contacts--pretty simple in older trucks.
    New starter will cost $$$$$--just buy the contacts at a repair shop and fix it yourself.
    I am sure there is a write up about "HOW TO"
  7. Nov 11, 2013 at 4:12 PM
    Constant
    Los Angeles
    shade and fuballs, i'll check both of those out when i've got some free time.
    newertoy, thanks for the info and how to check. my trucks been behaving for the past 2 weeks, so I'll keep something blunt and heavy in the back for when it starts (or doesnt) acting up, heh. The odd thing, though, is that when it doesn't start up, its dead silent, nooo clicking sounds.
    if it is the contacts, I found this
    I've a 2nd gen, but I would think it's all the same, right? I'm automotively illiterate so this is all trial by fire.
  8. Nov 11, 2013 at 5:47 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    It sure sounds like the starter is not engaging. everything else works fine and the truck will not start..
    If you can get the starter out-replacing the contacts should be EASY.
    If you do not feel that you are capable of replacing the contacts--take it to a repair shop--much cheaper than replacing. Call around to find the best place.
    Contacts should be about ten bucks--of course it has been a while since I have repaired one.
    Another thought--Manual transmission?--Clutch switch?
    You can use the clutch cancel switch on the dash
    OOPS see you have the auto!
  9. Nov 11, 2013 at 5:56 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Yes -that is the write up. Normally you do not need the plunger. Just clean it with some FINE sandpaper. Take off any carbon and your good to go.
    Keep it simple-lets be sure that it is the starter!
  10. Nov 11, 2013 at 10:54 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This happened to me once (no start, no click).
    It was the starter relay. Rule that out before working on the starter.
    After that, I'd look at the starter switch, like steves104x4 pointed out.
  11. Nov 12, 2013 at 5:38 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Most probably an oxidized or corroded electrical connector contact or a loose connector.
  12. Nov 18, 2013 at 2:08 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    FIXED?????? what did you find??
