Truck won't start! Help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awebber3, Feb 4, 2016.
  1. Feb 4, 2016 at 4:56 PM
    awebber3
    awebber3 [OP] TacoTacoTaco
    Andrew
    Charlotte, NC
    '07 DCSB Prerunner 3" lift
    Exterior: MBRP catback dual exhaust Smittybilt N-fab nerf bars Bilstein 5100 shocks & struts OME 885 & add-a-leaf Ballistic Jester 17" 265/70r/17 Nitto Terrra Grappler 5500K Retrofit Headlights (Mini D2S Stage III) Black badges, Black bull bar w/ LED Pods Satoshi Grill mod K&N air filter Tri-Fold bed cover Rearview camera EGR in-channel rain guards 10% tint rear, 10% tint front, 70% tint on windshield Pop-a-Lock tailgate handle Spidertrax wheel spacers Cab mount chop BIG 3 upgrade LED Running Board lights Black LED tail lights (’09 and up style) Black LED 3rd brake WOLO Air Horn Interior: Kenwood excelon DDX9703S 2 JL 10W1V3-4 10'' subs Alpine type-R component speakers in front Alpine type-S component speakers in rear Kenwood Excelon XR900-5 amp Weather Tech laser cut floor mats Cobra radar wired in Viper 5704 alarm w/ auto start & added glass break sensor and tilt sensor
    My truck is an 07 DC prerunner, just hit 100k miles. I went to work this morning and truck ran and started just fine. When I went to go leave work today the truck wouldn't start. All I got was one single "click". Me and my buddy went and picked up a new starter and after replacing it the truck still won't start. Still get the one single click. The battery is good, all lights and accessories work fine. The alternator was replaced less than 20k miles ago. I checked all the battery wires and they are solid and not corroded.
    Does anyone know what it could be? The only thing I can think of is maybe the starter relay. And insight on the issue would be greatly appreciated.
  2. Feb 4, 2016 at 5:00 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    How do you know that the battery is good? Did you have it tested? Just because a battery is showing 12 volts and all lights & accessories work doesn't mean it can turn the starter.
    Lester Lugnut likes this.
  3. Feb 4, 2016 at 5:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Starter relay is cheep and real easy. Sounds like a good place to check.
  4. Feb 4, 2016 at 5:25 PM
    smd3
    smd3 Well-Known Member
    check all the fuses.
  5. Feb 4, 2016 at 5:37 PM
    awebber3
    Andrew
    Charlotte, NC
    Fuses are all good, and I had someone try to jump me and nothing happened so I'm positive it's not the battery. I guess I'm going to get the starter relay and go from there. Or get it towed and let the stealership go at it.
  6. Feb 4, 2016 at 5:43 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    You're an 2007 with the OEM battery? OEM batteries are lucky to make it 4 years. Even aftermarket batteries don't last like they used to. I generally expect batteries to last between 4-6 years, and the first sign of trouble, replace the battery. Don't keep insisting the battery is fine unless you load lest it, not just take a multimeter to it, have a legitimate battery test on it.
    First thing you should have done is replace the battery.
  7. Feb 4, 2016 at 5:45 PM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    If your battery is far enough gone, trying to jump it alot of times isn't enough to get it fired up.
  8. Feb 4, 2016 at 6:08 PM
    cheech1
    Kaneohe, HI
    This. Even if you test it at somewhere like Autozone, if they don't load test it, they could tell you that it's fine. I wouldn't replace the battery without properly testing it.
  9. Feb 4, 2016 at 7:46 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Hopefully you didn't trade in your OEM Denso on a POS from one of the mass marketers.
  10. Feb 4, 2016 at 7:54 PM
    Jibber
    Jibber Active Member
    Jim
    Hopefully on the boat
    '95 and 79 Landcruiser and 01Taco
    Contacts good, connections tight...... only if you disconnect, clean and reconnect. Too many times I have grabbed the cable contacts on the batteries and felt they were tight and good. Doesn't mean shit.
  11. Feb 4, 2016 at 7:57 PM
    96_taco
    96_taco Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    It's gonna be either battery, relay, or starter that's the only places that relate to your problem.
  12. Feb 4, 2016 at 7:57 PM
    96_taco
    Clayton sandgren
    Northern va
    Also I would've kept the oem starter, they generally last a lot longer then 100k
  13. Feb 4, 2016 at 7:58 PM
    96_taco
    Clayton sandgren
    Northern va
    From your description, I'd take your truck to any dealer near you (doesn't have to be a Toyota) and ask for a free battery test. The tester we use here is an interstate ED18 tester.
  14. Feb 4, 2016 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you hear a click when you turn the key, Hint: That is the starter relay which should energize the starter solenoid which turns the starter motor. If you have already replaced the starter ( which includes the solenoid ) and the start relay is clicking the only thing left is a crappy connection or the battery isn't strong enough to turn the starter.
    Sometimes you need to connect the jumper battery and allow it to charge up the dead battery for a bit before it will start.
  15. Feb 4, 2016 at 8:04 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Battery.Probably cant handle the load.
  16. Feb 4, 2016 at 8:05 PM
    96_taco
    Clayton sandgren
    Northern va
    Try this too, reach down and smack the starter with a big bolt or something a couple times the try it lol
  17. Feb 4, 2016 at 8:07 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    What starter did you replace it with? Some aftermarket starters aren't exactly rebuilt as they state.... Click, means relay works. I'd test starter, and use another battery
  18. Feb 4, 2016 at 8:07 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Autozone's usually have a good load tester...only other reason a starter would only click is if the engine locked up...if everything else checks good, but in your case highly unlikely...
    also if you just had your alternator changed it typically burns up your battery...it maybe only one cell thats bad and when you put a heavy load like engine starter it doesnt have enough juice to crank but its enough for headlight, radio etc.....
  19. Feb 4, 2016 at 8:10 PM
    96_taco
    Clayton sandgren
    Northern va
    For real tho, since it started fine that morning and is just clicking now something must have just gone bad. Definitely check battery, then starter relay, then 4wd swap... Wait I'm getting off track
  20. Feb 4, 2016 at 8:19 PM
    wilcam47
    Will
    Bourbon state
    My Nissan Titan started ok the morning my battery went dead...it did have a few weird fluctuating lights/guages when I shut it off prior to going dead. I took it to Autozone and they load tested it and it died right there...just a click or two nothing else..
