Truck wont start occasionally, gas cap issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by WuTang, Nov 20, 2012.
  1. Nov 25, 2012 at 5:41 AM
    WuTang
    WuTang [OP] Well-Known Member
    SOMD
    2000 Tacoma v6 5 speed 4x4
    Deckplate Grey wire 2" Spacer lift 32's Retrofit
    Its a standard 5 speed and I do always push in the clutch when trying to start it
  2. Nov 25, 2012 at 7:09 AM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Make sure you have a good ground and check your starter wires on the starter.Its possible what you have is a loose connection down on starter. Clean your Battery Terminals. Might also be Starter Relay. Could be any of these things. I attached some info about the starter.
  3. Nov 25, 2012 at 4:15 PM
    BamaToy1997
    Bill
    Navarre, FL
    This can be tested, but now that we have the right information, diagnosis is a lot easier. The ful filter and such have no bearing on your issue. What you have is called a "Vehicle will not CRANK" complaint, not a "Vehicle won't START" complaint.
    As mentioned, you could have a starter issue or a clutch switch issue. (Or a few others) I would start with the basics: Verify that BOTH battery terminals are CLEAN and TIGHT. After that verify that the ground cable from the battery is tight where it connects to the engine. Bad connections in these areas are common for an intermittent "No Crank" issue. Once you have checked those things and verified they are good or bad, let us know.
  4. Nov 25, 2012 at 4:19 PM
    WuTang
    SOMD
    Ok I cleaned up the battery terminals really good and that didnt do it. Im gonna check the starter and relay right now
    EDIT: i also cleaned and tightened the ground connection when i cleaned the terminals
  5. Nov 25, 2012 at 4:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK, let me know what you find. One thing you can try is if you can find a matching relay for the starter (that is not an engine relay) you could swap it out temporarily. If you have a test light, you can check the terminal for the starter solenoid and work your way backwards towards the relay and such to try and locate the fault.
    If you have power at the solenoid when the key is in crank, but the starter does not engage, then do some searches on here for starter solenoid problems and there are a few threads that will explain how to fix it. However with your admitted lack of mechanical and auto electrical experience/knowledge, you might consider taking it in to get it repaired.
  6. Nov 25, 2012 at 5:10 PM
    WuTang
    SOMD
    FOUND THE SOLUTION!!!! I wasnt pressing down on the clutch hard enough when i would go to start it :rolleyes: go figure hahaha i came to this conclusion when it started right up when i pressed clutch start cancel lol Now on to the CEL!!!
  7. Nov 26, 2012 at 7:08 AM
    Sittingbull2
    Mitch
    Southeast texas
    I'm bailing on this it's yours BamaToy
  8. Nov 26, 2012 at 7:20 AM
    BamaToy1997
    Bill
    Navarre, FL
    Gee thanks. lmfao.
    OP, if you have a CEL on, you need to get the code read. It can usually be done for free at any parts store.
  9. Nov 26, 2012 at 7:56 AM
    WuTang
    SOMD
    hahahaha you can bail on me too if you want :rolleyes: i think i got it from here, its the same code as before p0420 i've patched up the leaks but still no luck. Im gonna go ahead and order new o2 sensors. My truck meets california emissions regulations so i gotta order cali sensors. thanks for all the help guys hhahaha hopefully someone else sees this and realizes they need to bring their seat forward and push in on the clutch harder :D
  10. Nov 26, 2012 at 10:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    I've not been one to bail on anyone. I was making a joke with SittingBull. Get those O2 sensors replaced and clear the code. We will go from there.
  11. Nov 26, 2012 at 11:14 AM
    WuTang
    SOMD
    You guys wont believe this..... the only thing holding the o2 sensor in place was the shroud around it which was rusted to the flange. I pryed it off with a screwdriver. you can see what i guess used to be one of the nuts on the left. so i found my main problem :D [​IMG]
  12. Nov 26, 2012 at 11:40 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Could be a contributor :)
  13. Nov 26, 2012 at 11:44 AM
    Sittingbull2
    Mitch
    Southeast texas
    I'm glad you found it. WTG just some looking and climbing around your truck you can figure alot of it own your own. I'm really glad i could help and Bama I'm sure is glad he could help also. If you need anymore just holler I'm sure me or Bama or anyone else would help you. I was just:frusty:
    Shittingbull LOL
  14. Nov 26, 2012 at 1:41 PM
    WuTang
    SOMD
    Lol ok thanks man im not as stupid as I probably came off with the whole clutch pedal thing hahaha tho it is going to be hard to justify that now :eek:First impressions can be the worst impressions :rolleyes: Any way i got the sensor off made a new gasket with some high heat gasket material and bolted her back up. Started it up and didnt feel any leaks. Hopefully the cel will go off on the way to work tonight. Thanks for all the help everyone and a special thanks to bama and bull!!
  15. Nov 26, 2012 at 2:04 PM
    #35
    Sittingbull2
    Mitch
    Southeast texas
    Welcome
  16. Nov 27, 2012 at 6:39 AM
    #36
    BamaToy1997
    Bill
    Navarre, FL
    No problem. I enjoy helping out whenever I can on this forum. I spend more time in the technical side than the chatting side to be honest. I have helped others, and have learned a few things myself that I can pass on to others.
  17. Dec 1, 2012 at 1:10 PM
    #37
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    It could also be intermittent electrical connection between the battery and the starter motor. The most common of these problems are corroded battery terminals or lugs. Like Mitch said, spark, compression and [atomized] fuel. Electrical faults can affect all of the above.
