Truck won't start
Discussion in 'Technical Chat' started by Tmanspd123, Jun 8, 2012.
  1. Jun 8, 2012 at 1:28 PM
    Tmanspd123
    Tmanspd123 [OP] Active Member
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I have a 95 Toyota with the 3.0 V6 that won't start. When I turn the key it just makes a clicking noise and does nothing. Checked all connections that I know of and battery is good. It doesn't make a content click just one click when key is first turned. I'm assuming I just need to go ahead and change the starter but wanted to see of any of y'all had any ideas or things to check before I change the starter. Thanks for any input.
  2. Jun 8, 2012 at 2:17 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Id you pull the starter most auto part stores will test it for you
  3. Jun 8, 2012 at 4:27 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    Thanks for the replies but I've figured it out. I was about to pull the starter and decided to check the wires and relays again. I pulled the tape off the main wire going into the fuse box under the good and noticed it was corroded around a connection. I cut the corrosion off add a fresh wire and started up perfect. I would've been pissed of I woulda changed the starter or even pulled it off and that not be the problem. Thanks again
  4. Jun 8, 2012 at 4:27 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
  5. Jun 8, 2012 at 4:55 PM
    Burgman
    Stephen
    Ric VA
    Glad you found the problem and it was a free fix
