true fact about intake
Discussion in 'Performance and Tuning' started by BAMFTACO, Dec 19, 2010.
  1. Dec 19, 2010 at 10:02 AM
    BAMFTACO
    BAMFTACO [OP] Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    So you know how intake say they reduce emissions, I tested it out I take autoshop in my high school and I used a sniffer it goes up the exhaust pipe to test the co2,Nox and other gases so I tested with the stock intake then with the after market one the results were lower emissions with the after market intake compared to stock one.
    So more power with better emission
  2. Dec 19, 2010 at 10:14 AM
    Crazyfrog
    Crazyfrog Well-Known Member
    Keith
    Monroe Ohio
    2010 TRD 4X4 DC
    OME 885's, Bilstien 5100, 2"AAL, Weathertechs, AVS visors, Access bed cover
    Punctuation? My eyes went crossed reading that.
  3. Dec 19, 2010 at 10:28 AM
    TWhit
    TWhit New Member
    Tim
    N.H.
    I'm glad I wasn't the only one.
  4. Dec 19, 2010 at 10:31 AM
    BAMFTACO
    Juan
    Kings bruh
    Edited hope its better now
  5. Dec 19, 2010 at 10:35 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    no not any better
  6. Dec 20, 2010 at 12:50 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    lol one period but thats cool
  7. Dec 20, 2010 at 12:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Now, my question is was the exhaust tested at operating temps during both tests?
  8. Dec 20, 2010 at 12:59 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    what he said^^^^^^
  9. Dec 20, 2010 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What they said. ALso, Engine at the same temp?
  10. Dec 21, 2010 at 8:30 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yeah like said above the cats need to be hot to get a real test..and if the truck is static then only TIME will generate heat if no load is involved..
    I used to do 3rd party dyno testing so I know how easy tests can be botched, we did over 5 runs per change during testing while monitering EVERYTHING you could imagine...
    I am just assuming but your first test was done "cold" and your next test (because of the first one) was much warmer and the cats are what helped your results.
    Even engine temp is not the final measurement needed, but that coupled with cat temp will help you get consistency.
    More info on the test?
  11. Dec 21, 2010 at 8:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    This was also my assumption.
  12. Dec 21, 2010 at 8:38 AM
    USFCON
    USFCON Well-Known Member
    Jeff
    Melbourne, Florida
    Prerunner SR5 Off Road
    FLM URD Short Shifter Debadged Gate 4 D-ring add on Weathertech floor mats Sport Wheel Swap Color matched Grill Bed lights Air freshner mod AAL Bilstein x 4 Tacolean Spacer Tins Bike Fork Mount Sexy Tires Blacked out Valence
    :facepalm::facepalm:
  13. Jan 1, 2011 at 9:24 PM
    BAMFTACO
    Juan
    Kings bruh
    I did it at operating temperature sorry for the late response
  14. Jan 1, 2011 at 10:14 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    yeah because your truck is probably running leaner
  15. Jan 1, 2011 at 10:16 PM
    BAMFTACO
    Juan
    Kings bruh
    Did not know that but I only did an emisions test and got better emissions with the cold air intake than the stock intake
  16. Jan 2, 2011 at 4:45 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
  17. Jan 2, 2011 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may have gotten a better reading due to the engine being closer, or at, operating temp.
  18. Jan 2, 2011 at 9:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Simply an observation. And without the temps being equal, too many variables to give a cunclusion. For one thing, If the OP pulled his truck into the test bay, after it was sitting for any length of time, Then ran the test, and stopped it, the engine is going to continue to get a little hotter than it was when he shut it off.....Much like a Turkey pulled from an oven tends to cook a little bit more, even though the heat source was taken away. Anyway.....Then the "Cold air intake" is installed, engine fired up, and tested. Being as its now at a hotter temp, it should be running "Cleaner", as the optimal emissions is reached at opperating temp. Now.....If the engine temp was monitored, and both tests were performed at 185*, with the same load on the engine (from a rolling dyno, much like an emission place uses), some accuracy can be had, and the title of this thread would prove more relevant.
