True or not true
Discussion in 'Technical Chat' started by Spencas, Dec 23, 2012.
  1. Dec 23, 2012 at 2:31 PM
    Spencas
    Spencas [OP] New Member
    Spencer
    Albuquerque nm
    06 PreRunner SR5
    Upgraded audio, hid, leveling kit
    The other day I went to a Toyota dealership to get transmission fluid and a tech said that they have to heat the transmission fluid before putting it in to the truck is this true
  2. Dec 23, 2012 at 2:38 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Sounds bogus to me.
  3. Dec 23, 2012 at 2:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The fluid needs to be at operating temperature (180?) before the level can be checked.
    A dealer may opt to pre-heat the fluid to save time.
    The "sealed" trans behind the 4.0 does not have a dipstick. It has a drain plug, fill plug, and a level check plug.
    With the temperature correct, the fluid should be at the level of the "check" plug.
  4. Dec 23, 2012 at 2:46 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Listen to this guy ^ He has his stuff down :thumbsup:
