True speed after regear formula.
Discussion in 'Performance and Tuning' started by WhatThePho?, May 4, 2011.
  1. May 4, 2011 at 12:34 AM
    WhatThePho?
    WhatThePho? [OP] Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    for first gens with stock 4.10 going to 4.88, and 31's going to 33's
    @ 55 real speed = 48
    @ 60 real speed = 52
    @ 65 real speed = 56
    @ 70 real speed = 61
    @ 75 real speed = 65
    Gear ratio change:
    (4.88-4.10)/4.10 = 0.190243902
    (New gears - stock gears)
    Tire ratio change:
    (33-31)/31=.06451629
    (current tire size- stock tire size)
    Then 0.06451629-0.1902= -.012568371
    Tire-gear ratio.
    Then add 1 and use the number to multply by your speed.
    -.012568371+1 = .87431629
    Take .87431620 and multiply by speed on the speedo. The answer will be your actual speed.
    33 with 4.88 is off by about 12.55 percent
  2. May 5, 2011 at 1:12 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    for second gens with a 3.73 rear going to 4.56. With 285/75/16.
    (4.56) -(3.73) then / by 3.73= .222520107
    (32.83) - (30.61) / 30.61 = .072525319
    (285/75) - (265/70) / 285/75 = ^^
    (.072525319)-(.222520107) = -.149994788
    -.149994788 + 1=.850005212
    .8500 x 55 mph = 46.75
    speedo reading = actual speed
    55 = 46.75
    60 = 51
    65 = 55.25
    70 = 59.5
    75 = 63.75
  3. May 5, 2011 at 1:17 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    for second gens with a 3.73 rear going to 4.88. With 285/75/16.
    (4.88) -(3.73) then / by 3.73= .350753617
    (.072525319)-(.350753617) = -.278228478
    -.278228478 + 1= .721771522
    .7218 x 55 mph = 39.699
    55 = 39.69
    60 = 43.31
    65 = 46.92
    70 = 50.53
    75 = 54.14
  4. May 5, 2011 at 1:17 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    saved for more
  5. May 5, 2011 at 1:17 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
  6. Jun 26, 2011 at 9:34 PM
    Chopper678
    Chopper678 Professional Threadjacker
    Devin
    Texas
    '07 SR5 PreRunner V6 DCSB
    5100s@0.85"+Eibachs, Toytec 2" AAL, Weathertech floor liners, WO seat covers, UltraGauge, ammo box mod
    I don't understand this. Why would you be going slower than what your speedometer read? And what are the effects of re-gearing?
  7. Jun 26, 2011 at 9:39 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Because your driveshaft is spinning faster than usual. It gives you more low end power.
    Stoking for me is 4.10 the drive shaft spins 4.10 times per wheel revelation. I went to 4.88, which means the driveshafts spins 4.88 times per wheel revelation. The speedo gear to determine speed is reading off the driveshaft.
  8. Jun 26, 2011 at 9:51 PM
    Chopper678
    Devin
    Texas
    So how exactly do you do this, and are there any downsides at all to re-gearing?
  9. Jun 26, 2011 at 10:00 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    It's all in your differential. You swap the gears in it out. Or swap the actual third member.
    Downside is your truck will be in a higher rpm. At 80 mph I'm at 3000. Before the regear I was at 2200. But I rarely drive 80 I mainly do 70 I saw a bit in mpg increase.
    Upside you have more lowend power. Great for 33 inch tires and bigger
    01MUD.TACO.SC.V6 likes this.
  10. Jun 26, 2011 at 10:06 PM
    Chopper678
    Devin
    Texas
    I'll probably never do it. Thanks for the info, man!
  11. Jul 3, 2011 at 6:57 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    hey andre,
    just came across your thread, seems like you're the guy to answer my question.
    i'm running 305/55 20's. the online tire converter tells me these are 33.2" tires. they're more like 33" when i measured them (tread wear).
    i have a 2nd gen and run stock gearing. can you tell me how much faster i am going relative to my speedo?
  12. Jul 3, 2011 at 9:59 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    cdelgado14 likes this.
  13. Jul 4, 2011 at 7:46 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    ^ thanks for the link!
  14. Feb 19, 2012 at 2:29 PM
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    I just used this, thanks.
    With my 33's and my new 4:10's I am only off by 0.08%
    When my speedo says I am going 65mph, I am actually going 64.525mph...
    Or, if I go 300 miles on a tank, I actually traveled 297.8 miles.
    (I came up with a correction factor of .9926979659.)
    Sweet, time to do a MPG check!
  15. Feb 28, 2012 at 1:39 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    I dont think this is accurate. On second gens the speed sensor is at each wheel so it measures the speed at each hub. Gearing does not affect the speedometer. Tire size does how ever. When going from a stock 30.6" tire to a 315/70/17 (34.5) the speedometer will be off between 12-13% giving you a slower reading on speedometer than actual speed going. When I am showing 65 on my speedometer I am actually going 72-73 mph. Same is true for mileage every 10 miles I drive I show 8.6 on the trip meter due to larger rolling diameter of the tires.
  16. Feb 28, 2012 at 4:20 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Then disregard the second gen part.
  17. Feb 29, 2012 at 9:08 AM
    commando
    Brandon
    Oregon
    3" spacer lift
    I just found this out also. I was driving down the interstate and using the milepost markers to double check my odometer.
    20 miles traveled registered 18.4 miles on my odometer.
    30 miles traveled registered 27.6 miles on my odometer.
    I found out I am actually off by 8.6682%
    I am running 255/85/16's (and I re-geared to 4:10's.)
    The good news is that at 65mph my rpm's are right around 2100rpm's.
  18. Mar 11, 2012 at 11:31 PM
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    so will 4.10 gears help me get better mpg? with 285/70/17
  19. Apr 25, 2012 at 12:12 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Everyone that has 4.10's and 33's said they saw an increase in fuel efficiency. Lets get some more responses from those guys.
  20. Apr 25, 2012 at 12:46 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Yes. On the second gen. Going to a 4.10 from a 3.73 is like the first gen going to 4.56 from 4.10.
