Trusted mechanic recommendation
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1st4x4, Feb 17, 2018.
  1. Feb 17, 2018 at 11:10 AM
    1st4x4
    1st4x4 [OP] Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    I live in torrance is there anyone close by that has a trustworthy mechanic. For simple stuff I have a mechanic but don't trust him doimg my valve covers as I've never seen him use a torque wrench and i know are valve covers arent on very tight
  2. Feb 17, 2018 at 11:50 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Bothwell in Torrance.
  3. Feb 18, 2018 at 2:53 PM
    Glamisman
    Glamisman Well-Known Member
    If it were me I would go to the various auto parts stores in your area, NAPA, O'Reillys etc and ask them who returns the fewest parts. The shop name that keeps popping up is the shop to go to. If a shop has a lot of parts returns it means that the techs there are guessing at fixing cars.
  4. Feb 18, 2018 at 5:58 PM
    Duty Bootie
    Duty Bootie Well-Known Member
    Richard
    Vancouver Island
    96 Taco Bush Truck - Now in Restoration
    Know an amazing guy in Norwalk if you need assistance.
  5. Feb 18, 2018 at 6:08 PM
    1st4x4
    sam
    Torrance
    I normally do my own work but have never done a timing belt or valve covers so was planning to pay someone to do it. Norwalk isn't to far if it's a weekend I'm down to help so I can learn. Got all new toyota oem parts.
    This is the list of parts I bought
    Timing Belt 13568-69095/YZZ03
    Idler Roller 13503-62040
    Tensioner Roller 13505-62070
    Front Crankshaft Seal 90311-40022
    Front Camshaft Seals 90311-38051
    Water Pump 16100-69398-83
    Water Pump Gasket 16271-62011
    PCV Valve 12204-62010
    Hydraulic Tensioner 13540-62021
    Thermostat 90916-03075
    Thermostat Gasket 16325-62010
    Air Conditioning Belt 99364-20870
    Alternator BeltToyota90080-91090
    Power Steering BeltToyota90080-91126
    Valve cover gaskets 11213-62020
    1/2 moons 11183-62010
    Cam plugs 11188-62010
    Washers for bolts for valve cover 90210-05007
  6. Feb 19, 2018 at 12:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    How did you go from valve covers to a timing belt??
  7. Feb 19, 2018 at 6:30 AM
    1st4x4
    sam
    Torrance
    I'm doing it all at the same time truck has 170k and factory timing belt
