Truxedo Lo Pro INSTALL $391 Shipped AutoAnything
Discussion in '3rd Gen. Tacomas (2016+)' started by TacoBella, Dec 3, 2015.
  1. Dec 3, 2015 at 4:46 PM
    TacoBella
    TacoBella [OP] Well-Known Member
    Tom
    16 4Runner Premium
    Running boards AVS in channel vents SpareBumper AVS Bug Deflector.
    AutoAnything had this for $391 Shipped in case anyone is interested in a roll up.
    Will keep relevant posts here including pics and install comments.
    OK So the install was not as easy as the Truxport but it is a better system.
    THe rails attach to the truck rails. Have to make sure you use the correct size washers....Derp....
    Received In Channel Vents and Lo Pro Tonneau this morning.
    Tools Needed 11mm 13mm Ratchets Screwdriver Phillips screwdriver The ability to read instructions that include a few types of Tonneaus......Fail Truxedo on that..
    Put the clamps together and slide them into the trucks rail channels Making sure to use the larger washers.....Derp
    Attach rails to channel brackets using Acorn nuts and smaller washers,
    This is NOT the way the washers go...derp again
    Leave everything loose and attach the front rail. It clips under the side rails and has a cool adjustment.
    Everything has to be loose to get both sides sliders to lock under the side rails. Adjust the tension.
    Use soft nylon trim removal tool to make sure the seals are correctly splayed out
    20151210_112745_HDR.jpg PROFIT
    Make sure all the seal lips are outside the rails and not tucked under.
    AVS Channel Vents
    Finished with one cup of coffee
    Desert_Dawg, gsxxr, ChaseFan and 3 others like this.
  2. Dec 3, 2015 at 5:52 PM
    TacoBella
    Tom
    16 4Runner Premium
  3. Dec 4, 2015 at 8:45 AM
    RZ1
    RZ1 Active Member
    This flair seems to be the problem area. Interested in how Truxedo cover handles this. I am assuming the seal will have to transition from insde the bed to on top of the bed. Some of the Access cover installs at this point seem to be problematic. Thanks for keeping us informed. I am also getting a super white. Nice truck.
  4. Dec 4, 2015 at 9:02 AM
    LaPorta
    LaPorta Well-Known Member
    Very interested as I'm looking for a roll up myself.
  5. Dec 4, 2015 at 9:04 AM
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    how did you get the savings? coupon code? or when you checked out it was discounted? I'm wondering if the discount is gone now, i keep getting it for 489
  6. Dec 4, 2015 at 11:51 AM
    TacoBella
    Tom
    16 4Runner Premium
    Just add it to the cart for $96 off Thats al I did. I put in CODE but it did not help. I think its an automatic 20% off right now
  7. Dec 5, 2015 at 1:57 PM
    TacoBella
    Tom
    16 4Runner Premium
    My last truxedo Velcro was overlapping the Plastic rail covers not inside the bed. I am betting that area will be where the latch is.
  8. Dec 10, 2015 at 9:39 AM
    TacoBella
    Tom
    16 4Runner Premium
    BUMP for Instructions for LO Pro
  9. Dec 10, 2015 at 10:25 AM
    ChaseFan
    ChaseFan Go Irish!
    Everett
    Southern Illinois
    SSM, 2019 Tacoma SR, Access Cab, 4X2
    It would take me one large Bubba Keg of iced tea to finish the job.
    TacoBella [OP] likes this.
  10. Dec 11, 2015 at 1:03 AM
    dutchjim
    dutchjim Well-Known Member
    Jim
    San Diego
  11. Dec 11, 2015 at 6:10 AM
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    I just installed my roll up cover, its an Access Tonnosport for $228, yes this price was on Syber Monday but you can get it for around $319 with the discount now.
  12. Dec 11, 2015 at 7:18 PM
    dutchjim
    Jim
    San Diego
    Looks nice and taught. I can't tell from the photos, but it looks like there aren't any gaps to let water in.
    A couple of questions for you.
    What do you think of it? Likes / dislikes. How long did it take to install? Was there any difference between the Access Tonnosport install and TacoBella's install? Did you get it from the Access company?
    Thanks.
  13. Dec 12, 2015 at 5:32 AM
    VinTaco
    Burnaby bc
    The install like any roll up is very easy, 1 size wrench ( 1/2 inch ) will do the whole job and in very short time, ( half hour to 1 hour ) if you do it alone. As far as gaps, when you look at the pic where the top is closed, you will see the end of the aluminum and tailgate meet, there is a gap there. I don't know how much water it will let in if any, being at the end I would think it would just run off or fall through between the gate and the box. There are always ways you can tweak it by getting some weather stripping ( sticky on 1 side ) and placing it where you need it. I just lucked out by buying it on cyber Monday so it was quite inexpensive for me.
    dutchjim likes this.
  14. Dec 12, 2015 at 12:45 PM
    austinmuench
    austinmuench Member
    Austin
    2016 Toyota tacoma sr5 xp
    i installed mine about a week ago. Love it! havent adjusted the tension yet.
  15. Dec 12, 2015 at 7:02 PM
    dutchjim
    Jim
    San Diego
    Is this the TruXedo Lo Pro QT Soft Roll-Up?
  16. Dec 12, 2015 at 7:20 PM
    austinmuench
    austinmuench Member
    Austin
    Yes it is. When i went searching for it online tonneau covers world was the only one that had it.
  17. Dec 13, 2015 at 5:47 AM
    VinTaco
    Burnaby bc
    Would you mind taking a pic from the side, just want to see how the cover sits on the box..Thanks
  18. Dec 13, 2015 at 9:15 AM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    I would like to see how easy it is to remove the low pro cover. I need to take it off at times and want one that basically a few clamps and no tools. From what I understand this is the only one but haven't been able to see one from inside the bed looking at the corner how it mounts.
  19. Dec 13, 2015 at 9:51 AM
    austinmuench
    austinmuench Member
    Austin
    IMG_0940.jpg IMG_0941.jpg it is removed by lifting a single tab at the rear, rolling up the cover, and at the back their is two tabs that your pull towards the center of the cover. Then you can lift up and take off the cover. The side rails stay on of coarse but you can still use your rail as a tie down point.
  20. Dec 13, 2015 at 9:51 AM
    austinmuench
    austinmuench Member
    Austin
    there is no tools involved in taking off the cover.
