TruXedo LoPro vs. Access Lorado
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scienceguy, Jun 28, 2009.
TruXedo LoPro or Access Lorado?
Poll closed Jul 28, 2009.
  1. TruXedo LoPro
    1 vote(s)
    33.3%
  2. Access Lorado
    2 vote(s)
    66.7%
  3. Get another brand!
    0 vote(s)
    0.0%
  1. Jun 28, 2009 at 4:53 PM
    scienceguy
    scienceguy [OP] Well-Known Member
    SW Wisconsin
    09 TRD OffRoad 4x4
    Howdy!
    I am looking at putting one of these covers on my 09 DC Short Bed. I think there are pros and cons to each and I could use some help making my decision. Here's how I feel about each so far...
    The TruXedo Lo Pro's benefits are the lifetime warranty and the automatic tension adjustment. One downside that I've heard with Tacomas is that once installed, you lose some function of the sliding rails on the inside of the box.
    This is where I've been told the Access Lorado works well with Tacomas. Once installed, the sliding rails still have full function. However, I don't believe the Lorado has a lifetime warranty or automatic tension adjustment.
    For those of you that have either of these covers, please let me know what you do or don't like about them.
    If you don't have one, but could share some knowledge on the subject, please do!:)
  2. Jun 28, 2009 at 5:08 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    truxedo i have had one for 3 years on a nissan frontier worked amazing.....sumer winter never had to adjust it
  3. Aug 6, 2009 at 2:49 PM
    shaX 07
    shaX 07 Member
    Maine
    05 SWB X-Runner
    B&M SS || BHLM || Tinted Tails || 20" Stern ST-1 Face III Beast || 2525 Aero Turbine Exhaust || 1.5" Rear Drop || 8K Head/Fog HIDs || 35% Tint || NST LW Crank Pulley || s2k Antenna
    I'm currently having the same debate between these 2 covers... we need more input!!!!!
  4. Aug 6, 2009 at 3:03 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Advantage Accessories. Locks in to factory bedrails in about 2 minutes. Less time after initial install. Its tri-folding and hard shell vinyl covered. Removable in about 30 seconds. Seals up rather nicely. Retain use of factory bedrails still.
  5. Aug 7, 2009 at 2:32 AM
    silver6
    silver6 Member
    Frankfort, Ky
    Tacoma Double Cab 4x4 Sport
    Brand new
    Love me some truxedo! Had one on my chevy hd and loved it too!
  6. Sep 26, 2009 at 4:42 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    x2. We need some more pics of each installed and pros/cons of each.
  7. Sep 26, 2009 at 9:33 AM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    love my truxedo, ill take a picture today and upload it
  8. Oct 21, 2009 at 2:03 PM
    savit260
    savit260 Member
    I'm also interested in the Truxedo. I'm seeing conflicting results after a search about the bed rail cleats. Is there enough clearance to use the factory sliding cleats or no with the Truxedo Lo Pro? Are there any other issues with the bed rail system and the Truxedo?
  9. Oct 21, 2009 at 2:11 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Advance Cover
    http://www.advancecover.com/
    http://www.kcovers.com/ can buy here
    Awesome 4 fold, super easy to install especially the new model, I have the older one. Easy to take off, keep the use of the rails. Fold either way and locks on both sides.
    I have had about 10 people offer to buy mine off of me on the street when they saw it function.
  10. Oct 26, 2009 at 1:20 PM
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
  11. Oct 26, 2009 at 1:58 PM
    savit260
    savit260 Member
    Thanks. Ended up going with the Truxedo, and the factory cleats are still usable. :)
  12. Oct 26, 2009 at 7:09 PM
    tacomiker
    tacomiker Well-Known Member
    Indianapolis Indiana
    2016 TRD Sport
    Tint, Lo Pro tonneau cover,Weather techs, BFG AT ,
    I have had the truxedo on three different tacomas and think they are the best out there.Lifetime warranty and have had no problems,:)
  13. Oct 26, 2009 at 7:59 PM
    altarossco
    altarossco Active Member
    San Ramon, Ca
    2010 double cab pre runner
  14. Oct 27, 2009 at 9:08 AM
    amati5
    2010 Prerunner TRD
    Had it on my previous Titan too, flawless design. We took it to Grand Cyn in the storm and the bed was full of stuff, not a single drop of water got in.
  15. Oct 27, 2009 at 9:31 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Both the Truxedo lo-pro and the Access Lorado are very nice covers that will give you great protection and use for years on end. I highly doubt you will be able to use the tie-down cleats with the lo-pro, the top just simply sits to low for clearance with the factory cleats. If you got the mini cleats it may work fine. Those above instal instructions are "in general" for installing a truxedo cover, it does not say Lo-Pro specific (that I could see atleast)
  16. Oct 27, 2009 at 9:54 AM
    amati5
    2010 Prerunner TRD
    Based on my previous LoPro, the cover sits almost an inch above the bed but it looks low because of the angle. The cleats are parallel to the bed and I think lower than the bed top so I can't imagine they even touch each other. But I'll post when I get it. Someone has picure of the installed LoPro ?
  17. Oct 27, 2009 at 1:33 PM
    savit260
    savit260 Member
    The factory cleats fit below the mounting rails, and between the brackets that the rails mount to. They have enough clearance to slide back and forth, but can't slide past the mounting brackets. I have one cleat between each bracket, so I pretty much have most of the length of the bed covered if I need to slide the cleats forward or back. A bit of a comprimise, but it should work just fine.
  18. Oct 27, 2009 at 3:39 PM
    amati5
    2010 Prerunner TRD
    That's exactly what I thought based on the instruction above.
  19. Oct 28, 2009 at 7:09 AM
    Kartner
    Kartner New Member
    Karl
    Ontario, Canada
    '09 DC TRD Blue
    I'm in the same boat here looking at the Truxedo lo pro. It's great to know that the cleats will still work with the brackets installed, but I'm wondering if anyone has any pictures of this at all? I'd just like to get an impression of how it's going to look and work.
    Thanks!
  20. Nov 5, 2009 at 10:48 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    I was wrong! the LoPro does work with the tie-downs, you just loose a little of the mobility of them sliding up and down the track rail.
