Truxedo LowPro QT installed today
Discussion in 'Product Reviews' started by inlinejohn, Apr 15, 2010.
  1. Apr 15, 2010 at 8:12 PM
    inlinejohn
    inlinejohn [OP] Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    Received my tonneau cover from Truxedo yesterday and was very anxious to install, so I tackled it tonight. Did it by myself in about 1 hour.
    Instructions were pretty good with graphics, etc. I got a little anxious and tightened a few bolts up before final adjustment. No big deal. Just loosened and got it set properly.
    Taking D-tie downs was required and very easy. Pics will show that the cover mounting brackets and stock D-tie downs share the factory rails, so the order of installation is very important.
    First in is the bracket followed by the D-tie down:
    Following in order was next cover bracket, 2nd D-tie down, last cover bracket, end rail cap:
    as you can see the D-tie downs fit, but not much room above between tie down and underside of rail. Might be a challenge to get a hook around the tie down, but probably possible:
    clearance is about .25"
    bracket of cover mounted in factory rail and bolted to cover rail
    other side was just as easy
    cover latch only on left side
    rails installed, cover mounted (pretty easy)
    forgot to show fwd seal installation,but it was simply a thick foam seal with double back tape and you just stick directly to the top of the truck bed rail at cab
    cover rolled out and latched
    installed and looks awesome
    Haven't driven with it yet, but am excited to test it out. It rolls open easy, closes nicely and seems to have most everything sealed pretty well. Not 20 fathoms waterproof, but will keep most rain out.
    Ordered my Pop&Lock tailgate lock today, so that is next install. Bed isn't completely secure until the ability to lock.
    Overall, I'm very happy with the Truxedo LowPro cover, as I researched both Truxedo and Access and chose Truxedo for one main reason. The brackets share the factory rails, rather than go behind like the Access. I'm sure the Access is just fine, but I liked Truxedo better.
    Hope this helps the next install for someone.
    Have fun!!!!
    Deathray likes this.
  2. Apr 15, 2010 at 8:20 PM
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    That looks great! I want one
  3. Apr 15, 2010 at 8:33 PM
    inlinejohn
    Washington
    Love the cover :)
  4. Apr 15, 2010 at 8:39 PM
    got_titan
    got_titan Well-Known Member
    sevierville, tn
    2010 trd sport dc 4x4
    great write up and picks! just ordered one today from luke @truck alterations. hes a tw sponsor...345 shipped...i really liked the truxedo but looks like it going to be hard to use the tie down cleats being they are so close...that kinda sucks...the access allows full operation of the cleats....thanks again for picks!
  5. Apr 15, 2010 at 8:44 PM
    inlinejohn
    Washington
    Truthfully, I think you could carve a little bit of the Truxedo rail right above the D-tie down and have full access to it. I will contemplate this idea. Of course don't want to damage the functionality of cover/rails, but I think taking only a little material out would be ok.
  6. Apr 15, 2010 at 8:48 PM
    got_titan
    sevierville, tn
    that sounds like a good option, i liked how low the truxedo rides much better than access...after looking at your picks the access does allow the cleats to move around freely without restriction....i have had great luck with the truxedo on my titan and the truly do stand behind the lifetime warranty....
  7. Apr 15, 2010 at 9:29 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    dam i had one of those on my titan, those are great, rolls right up in seconds to utilize to whole bed, and looks bad a$$
  8. Nov 21, 2010 at 6:20 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    hey inline
    after the install are the factory tie downs still functional, are you able to still move them around and take them off as well?
  9. Nov 21, 2010 at 6:39 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    yes
  10. Nov 23, 2010 at 4:48 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    Great cover! mine had a couple factory gluing flaws so I took out the D rings and carved out the holes slightly to lower the cover so it would seal around the edges. Works great now
  11. Nov 30, 2010 at 8:15 PM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    Man I want one, but it is so overpriced for what it is.
  12. Dec 13, 2010 at 5:13 PM
    pretzel
    pretzel Well-Known Member
    TX
    2010 Tacoma 4 cyl
    So, have you tried to put a hook through that tie-down yet?
    Cover looks great, btw...almost ready to pull the trigger on one, but that would be an issue if I couldn't hook into the cleat.
  13. Mar 8, 2011 at 7:59 PM
    clintrob
    clintrob Tacoma *****
    Clint
    Charlotte, NC
    07 DC 4X4 Sport
    Leather, XM Radio, Running Boards, Truxedo LoPro
    Excellent write up and helped in my decision. Looks great on the silver Tacoma.
  14. Mar 15, 2011 at 7:06 PM
    AC13JohnG
    AC13JohnG Señor Member
    Black 5 lug
    I have the same one.....A++++ worth every penny.
  15. Oct 27, 2016 at 1:39 PM
    AmorPatriae
    AmorPatriae Well-Known Member
    12 DCSB SR5 4x4
    TRD Sport Hood, Truxedo Lo Pro Tonneau cover, OEM Bed Extender, SOS Front Bumper, SOS Rear Bumper, Pro Comp 84 Series Vapor, Goodyear Wrangler Duratrac
    Alright folks, it's been a while since this forum has been touched. Has anyone installed a low pro with the OEM bed extender. I just tried and it's hitting the cover support. Any suggestions?
