Try and figure this one out? CEL on for 3 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rock4200, Aug 18, 2008.
  1. Aug 18, 2008 at 9:03 PM
    rock4200
    rock4200 [OP] Active Member
    Maryland
    SR5 TRD Off-Road 6spd manual w/ Towing Pack
    Black headlight mod, Sockmonkey's lower blackout grill
    First let me say I have taken the Truck to Toyota and they do not know what is wrong with it!!!
    Now with that said. I have 2005 6spd toyota tacoma TRD pckg V6 92,000 miles on her. CEL came on about 3 months ago it is reading a p0173 code. I replaced the MAF I replaced the heated oxygen sensor ( above the cat converter)all with OEM parts. CEL light still on. I have had it two mechanics, they couldn't find the problem. I broke down took it to Jerry's Toyota In MD they had it told me they could not figure it out, the gas smelled week. They told me two run a higher grade of fuel then wanted to charge me 95.00 ha ha I told them to eat $h%t. So i was on my second tank of higher grade fuel, when the light went off for 1 day and then came back on and stayed on. It is bogging a little when I am in 3 or 4th gear accelerating then runs fine when she catches up. any thoughts?
  2. Aug 18, 2008 at 9:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just curious if you have a cold air intake?? try cleaning the maf sensor!! also......its possible that one of the spark plugs may be cracked, or that you may have a cat. converter thats starting to fail. try cleaning the maf sensor first.
  3. Aug 18, 2008 at 9:23 PM
    rock4200
    Maryland
    already did that now I also put a brand new one in there and no just OEM intake
  4. Aug 18, 2008 at 9:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats a tough one man!!!
  5. Aug 18, 2008 at 11:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If your gas cap tight?
    Stranger things have happened....
    I know on the 1st gen trucks, a loose gas cap sets off a CEL sometimes.
  6. Aug 18, 2008 at 11:45 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    So what does p0173 mean?
    That might explain it.
    If not, break the light, change the oil and drive her another couple hundred thousand miles.
    I mean seriously If Toyota doesn't know whats wrong with it WTF! they built it right?
  7. Aug 18, 2008 at 11:48 PM
    Swwacoma
    Swwacoma Doomsday Squad
    Estero, FL
    08 PreRunner SR5.
    Long shot but if you're ecu/ecm is starting to go a little crazy it can say its a MAF malfunction. Happened in my 03 corolla as well as my brothers 07 corolla (possibly just a corolla thing, but it sounds similar).
  8. Aug 19, 2008 at 12:22 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    P0173 - Powertrain: Fuel Trim Bank 2
    What about disconnecting the battery for a little while & reconnecting? Doesn't this reset the ecu?
    Found this info on Google:
    "Usually P0170 and P0173 mean your Mass Air Flow Sensor took a crap. However, it can also be caused by vacuum leaks, etc."
    "P0170 (right bank)& P0173 (left bank) are fuel trim codes.
    Check for vacuum leaks, air intake leaks (air cleaner tube), incorrect fuel pressure, bad fuel pressure regulator or faulty injectors. "
    Technical questions:
    http://204.16.221.2/direct/view/.ef2398d/203
  9. Aug 19, 2008 at 5:47 AM
    rock4200
    Maryland
    I am starting to think it is an injector problem , like said the MAF is new from toyotA. i ALSO HAVE RESET THE LIGHT 6 OR 7 TIMES USUALLY COMES BACK ON AFTER 20 MILES OR SO
  10. Oct 11, 2008 at 11:38 AM
    rock4200
    Maryland
    Ok, follow-up CEL light is still on
    but could I be getting this code from the cat converter I now notice a deep like humming sound when I start the truck up and accelerate and it is still bogging when I accelerate. Maybe Toyota missed that the converter was going up? anything else?
  11. Oct 11, 2008 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Is that the ONLY code your getting?
    That code is quite common for a bad MAF. Being as you said you have a new one, Im not sure what else it could be. Did you check all the vaccume lines? :confused:
  12. Oct 11, 2008 at 12:58 PM
    rock4200
    Maryland
    I can't seem to find a vacuum leak anywhere
  13. Oct 11, 2008 at 6:09 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Had to have both front cats replaced on my '05 when the truck only had less than 30,000 miles on it. That meant both manifolds and cats.
    Marc M
  14. Oct 11, 2008 at 9:07 PM
    TexasJay
    TexasJay If..Then..Else
    Jay
    Oak Point Texas
    Prerunner SR5 - Longbed
    EGR Bug Deflector, Tacoma Bed Mat, Remove secondary air filter, Yakima Roof Rack, Cobra CB Radio, Bilstein 5100 set to 1.75 in front, 1.5'' Block in rear.
    I don't know if this applies to Tacoma's but I had the same problem on an old chevy truck I owned many moons ago. It didn't have a CEL, but would bog down every time I tried to give it gas.
    Several mechanics looked at it and I had them tell me everything from I need a new transmission to new heads.
    Turned out to be a fuel filter. It was restricting flow to the engine and it would starve the engine of fuel.
  15. Oct 11, 2008 at 9:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That very well could be the issue. Not sure if it would throw a code. :confused:
  16. Oct 12, 2008 at 4:39 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Is the new MAP sensor any good? Stranger things have happened.
  17. Oct 12, 2008 at 5:11 AM
    rock4200
    Maryland
    I have a new MAF not a MAP
  18. Oct 12, 2008 at 6:56 AM
    TicTacOma
    Columbia,SC
    ok, is the new MAF bad? Never answered the question even though it was wrong but you knew what I meant.
    Do the ol' Electrical Tape mod and you'll be able to sleep better, I know I will.
  19. Oct 12, 2008 at 7:31 AM
    rock4200
    Maryland
    yeah sorry no it is good I have checked, plus it went to Toyota after I installed the new MAF. Thanks for the info
  20. Oct 12, 2008 at 7:36 AM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    a vacuum leak should give a bad idle and shouldn't really cause the bogging down when at speed. A clogged cat should come up as a cat inefficient code. Perhaps the wiring TO the maf? Can you run the car with the MAF unplugged? See if it changes driving character. I know on GM cars you can unplug it and it will go to default tables (and obviously throw a code).
    What does gas smelling weak mean?
