Try and figure this one out? CEL on for 3 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rock4200, Aug 18, 2008.
  1. Oct 12, 2008 at 7:55 AM
    rock4200
    rock4200 [OP] Active Member
    Maryland
    SR5 TRD Off-Road 6spd manual w/ Towing Pack
    Black headlight mod, Sockmonkey's lower blackout grill
    The gas smelling weak was What Toyota told me. So, since then I ran 6 -7 tanks of high octane gas threw it I normally use 87. But the light is still on so I am ruling out that I had a tank of bad gas.
  2. Oct 12, 2008 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you checked the fuel filter? Also, try clearing the code with a scanner.
    Im still puzzzled about this issue. :confused:
  3. Oct 21, 2008 at 10:08 PM
    TexasJay
    TexasJay If..Then..Else
    Jay
    Oak Point Texas
    Prerunner SR5 - Longbed
    EGR Bug Deflector, Tacoma Bed Mat, Remove secondary air filter, Yakima Roof Rack, Cobra CB Radio, Bilstein 5100 set to 1.75 in front, 1.5'' Block in rear.
    I just checked back in on this thread to see what the resolution was. Looks like it's still in trouble shooting mode. Bummer. If you find the problem please let us know. I'll just sit here and wait.:bored:
  4. Feb 11, 2009 at 9:16 PM
    rock4200
    Maryland
    Ok so here is an update to a thread almost started a year ago. The other day I got in my truck to move it and to my surprise the CEL light was off! Since then I have driven it about a total of 20 miles. It has been on for almost a year now its off mmmmmm any thoughts??
  5. Feb 11, 2009 at 9:34 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    possessed
  6. Feb 11, 2009 at 9:55 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Weak fuel pump? Clogged fuel filter? Something caught in gas line or injector? Bad spark plug?
  7. Feb 11, 2009 at 10:03 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
  8. Feb 12, 2009 at 5:26 AM
    rock4200
    Maryland
    nope plugs been replaced with ngk iridiums
  9. Feb 12, 2009 at 5:33 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Great, now there is something wrong with your CEL. :D
  10. Feb 12, 2009 at 5:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    CEL burned out?
  11. Feb 12, 2009 at 6:06 AM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    My guess is a vacuum leak or a weak fuel pump.
    One old trick for checking for pesky vacuum leaks is to take one of those hand held propane torches and turn the gas on (don't light it, LOL) and move it around all suspect areas including intake gasket areas etc. If you hit a spot and the idle speeds up dramitically, you found your leak :)
