Trying out 93 Octane Fuel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, Jun 27, 2009.
  1. Jun 27, 2009 at 1:21 PM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    I filled up today for the first time with 93. Truck has like 8,600 miles approx. Stock with minor mods in sig. I've been averaging 18.3-19.0 on 87. 93 is .20 cents more per gallon. With today's prices it's 7.5% more expensive. so I'd have to get 7.5% better MPG's to break even. So I'm going to need a 1.39 MPG jump. Somehow I don't see that happening from just running 93... But I'm going to try it.
  2. Jun 27, 2009 at 1:27 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You'll have to run a few tanks through the engine before the computer fully calibrates from the octane change FYI.
  3. Jun 27, 2009 at 1:51 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Really? What about a reset?
  4. Jun 27, 2009 at 1:53 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would go atleast 3 tanks before really noting the changes.
  5. Jun 27, 2009 at 1:57 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Still take a few tanks before the engine is fully optimized for the octane levels.
  6. Jun 27, 2009 at 2:02 PM
    brian
    Elizabeth City, NC
    I see. I just started running 93/91 again.
  7. Jun 27, 2009 at 4:15 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    There are going to be too many variables to decide whether the octane was responsible for 1.39mpg difference. Personally, I run what the manual says and focus on a lighter right foot if I want better gas mileage.
  8. Jun 27, 2009 at 4:23 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Does anybody notice any pinging or piston misfires with 87?
  9. Jun 28, 2009 at 5:05 AM
    jandrews
    '09 FourDubDee TRD OR
    Nah.
    However:
    Current-gen V6 taco's had their engine's spec'd with 91 octane, so you get the most out of your engine with 91-93.
    As far as gas mileage, changing octane won't make much of a difference for most people. There are four main things that will have a meaningful impact on gas mileage that adults with responsibilities have enough time to do:
    - Service your vehicle properly, with the recommended parts/fluids, at or before the recommended mileage/time intervals.
    - Check your tire pressure regularly (once a week or so) and make sure you are at proper inflation. Increased inflation will help your gas mileage a bit more BUTT (_|_): never exceed maximum inflation pressure listed on the tire, and be aware the truck will ride stiffer with higher tire pressures.
    - Drive with a light foot. Slow acceleration, easing through turns, etc. isn't sexy, but it will save you gas. Lower RPM = less fuel consumed, period.
    - Avoid carrying heavy loads (IN MY TRUCK?!?!?!). No, I'm not saying stop hauling. It's just a simple fact of life that more weight requires more energy to move, and more energy eats more fuel. If you don't use something in your truck regularly and it's heavy (i.e. tool box, heavy ass equipment) take it out of the truck for storage rather than tooling around town with it in the bed. If you have a DC, expect lower mileage with a full passenger load than driving by yourself.
    There you are. Enjoy your mileage. Even if you don't see an improvement with 93, keep running it to keep your engine happy. She'll thank you 250,000 miles down the line.
  10. Jun 28, 2009 at 8:25 AM
    FL4x4Taco
    10:1 compression is pretty dang high. That would be unheard of 10-15yrs ago running a engine like that on 87 in the summer time of FL. Most those older cars I knew had 8.5:1 - 9.5:1. 10:1 + was considered a hotrod ya know. I will read my owner's manual again, and try 3 tanks of 93. Then make my long term decision there.
  11. Jun 28, 2009 at 8:32 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    My truck seems to like the 87 best. No problems with it at all. However, if I'm towing I will go with 91 to prevent detonation.
  12. Jun 28, 2009 at 9:18 AM
    Incognito
    VA
    Alright, thanks for the info guys. :cheers:
  13. Jun 28, 2009 at 9:39 AM
    FL4x4Taco
    I'll post up my next 3 tanks of 93, just for the sake of trying it. So far my 87 tanks have been... 18.3-19.0 Avg. We shall see what 93 yields.
  14. Jun 28, 2009 at 12:13 PM
    Incognito
    VA
    Sounds good. :)
  15. Jun 28, 2009 at 12:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    You should notice some improvement in throttle response. Specially in the higher gears if you decide to bury it.
  16. Jun 28, 2009 at 12:38 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    I have used 93 octane since day 1 and I am happy but I can't compare the difference to 87 octane. Thank you company gas card!!! :D
  17. Jun 29, 2009 at 4:01 AM
    FL4x4Taco
    Well I have about 30 miles on the 93. I can tell the throttle response is better. It does drive a bit better. And Im the skeptical kind of guy. After 3 tanks we'll let the $/mile tell me what I need to buy. But if I'm towing or screwing around, deff getting 93.
  18. Jun 29, 2009 at 8:36 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Cost per mile would be the most effective way of measuring which is saving you more.
  19. Jun 29, 2009 at 8:50 AM
    FL4x4Taco
    which is what I stated above.
  20. Jun 29, 2009 at 11:44 AM
    bermise
    Houston
    08 TRD off road
    How much money would you save with 1 mile per gallon better in a year?
