Trying to add amp and sub to entunes premium 2017 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eyesells, Jun 9, 2019.
  1. Jun 9, 2019 at 6:33 AM
    eyesells
    eyesells [OP] New Member
    Terry
    Franklin Tn
    2017 Inferno TRD
    I cant find a clearly marked diagram that tells me which wires are the tweeter, front speakers door and rear door speakers. I want to convert those to rca for amp input and then back out to upgraded speakers. Any help would be much appreciated. Also need to know where to run the blue lead from the amp to head unit.
  2. Jun 9, 2019 at 6:37 AM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    @destin_meeks
    He may can help.
    eyesells[QUOTED][OP] likes this.
  3. Jun 9, 2019 at 6:48 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I would get the metra 70-1761 and 71-1761 to build a T-harness behind the radio. That will get you color-coded speaker outputs from the radio and then inputs to the factory wiring to do exactly what you want to do.
    For the front door vs tweeter, there is actually only 1 pair of wires coming from the radio.
    It comes out of the radio, over to the factory tweeter, then out of the factory tweeter into the door panel. If you’ve looked at the tweeter, that’s why it has 4 wires
  4. Jun 9, 2019 at 6:56 AM
    eyesells
    Terry
    Franklin Tn
    2017 Inferno TRD
    Thanks here is a pic of front speakers. What colors are rear speakers?upload_2019-6-9_8-56-2.jpg
  5. Jun 9, 2019 at 7:01 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I used the rear speakers from the back of the HU. Don't remember the colours anymore unfortunately, but I think they were on their own on a white 4 plug module.
    eyesells[OP] likes this.
  6. Jun 9, 2019 at 7:04 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Rear speakers are in the second, smaller harness next to that one. I want to say left is white-black and right is blue-green
  7. Jun 9, 2019 at 7:07 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
  8. Jun 10, 2019 at 7:31 PM
    CO_Taco125
    CO_Taco125 Well-Known Member
    '17 TRD OR DCSB
    Blackhawk Tune, Falken Wildpeaks, Falcon Suspension, KMC XD, KC flexpods, KC Pro6 bar, Kicker speakers, Sound Ordnance sub, MTX amp, interior vinyl wrap
    Take signal from the rear speaker wires to the amp, and run new wire from the amp to your doors. That way its easy to get the signal, and you can run larger wire for the increased power from the amp. An active line output converter would be a good investment as well, such as the LC2i.
  9. Jun 10, 2019 at 7:36 PM
    eyesells
    Terry
    Franklin Tn
    2017 Inferno TRD
    Thanks for all the good info. Finished today and it’s awesome. 4jbl coax 1200 watt cerwin Vega amp and 800 watt 8 inch sub.
  10. Jun 11, 2019 at 7:19 PM
    FZfreak
    FZfreak New Member
    2016 TRD Sport Inferno Access
    a related question, pls: what wire @ HU can be used to turn-on/wake-up the amp ? thx.
  11. Jun 11, 2019 at 7:22 PM
    eyesells
    Terry
    Franklin Tn
    2017 Inferno TRD
    Gray wire refer back to pic in this thread. It’s the switch pwr wire.
    FZfreak likes this.
