Trying to fit 285/75R16 on stock wheel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by chvymechanic, Apr 29, 2011.
  1. Apr 29, 2011 at 10:42 PM
    chvymechanic
    chvymechanic [OP] Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    Maybe the 285 aren't worth the hassle of trying to make them fit.
    Are you happy with the 265/75/16? Any rubbing with those?
  2. Apr 29, 2011 at 10:50 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Very happy with the 265's, though sometimes I do miss the 285's for offroad capability and looks. However when I fill up I remember my love-hate relationship with the 285's! Zero rub with 265's. Good luck, show pics!
  3. Apr 30, 2011 at 12:12 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2
    i drop quite a bit of money on gas with 285-75 KM2s...
  4. Apr 30, 2011 at 12:29 AM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Yeah and with continually rising gas prices it might be smart to stick with a 265. That way no spacers or rubbing issues.
  5. Apr 30, 2011 at 10:56 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I've got 285/75's. Hell I still rub with 4" BS a tiny bit on the drivers side frame. Has to be full lock left turn and a very hard compression, but it rubs. Only the frame and not enough for me to give a shit. Small price to pay for the size I wanted. I also have a shiney spot on my frame now. :D
  6. May 1, 2011 at 8:50 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    NegroTundra when you ran the 285's did you have the stock UCA?
  7. May 2, 2011 at 5:07 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Is it necessary to remove the front mudflaps to fit 285's? I see that the pinch weld sticks past the mudflap and would like to keep the mudflap it if at all possible.
    Thanks
  8. May 3, 2011 at 9:29 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
  9. May 3, 2011 at 9:46 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    I had to take mine off. After doing the pinchweld mod, the mounting in the middle for my mudflaps wouldn't work anymore. Also I think they would hit the tire anyway.
  10. May 3, 2011 at 9:54 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    did you try adjusting your caster forward?
  11. May 3, 2011 at 9:56 PM
    Taco76087
    Robert
    Weatherford,Texas
    Oh yeah I got everything set, I just left them off because i've got sliders anyway.
  12. May 3, 2011 at 10:13 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Think I am going to get Hankook DynaPro ATM RF10 LT285/75R16 and run a 1/4 inch spacers in the front to pull it out from the UCA. Making the backspacing roughly 4.375". Any thoughts on using just a 1/4 inch spacer since I have have the Light Racing UCA?
    Thanks
  13. May 4, 2011 at 11:31 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    The UCA is not really the main rubbing problem here. You can clear an aftermarket UCA with a 285 on a rim with 5" BS (I know for fact...took the 285's off my wife's runner and put them on my Tacoma to see). I see no reason why you wouldn't clear a factory UCA with a 4.5 BS. You're going to rub on the frame though.
    I would advise against the 1/4" spacer on stock wheels for 2 reasons.
    1) The lugs on the Toyotas are short. You need all the thread you can for your wheels.
    2) Spacers are designed for LUG centric applicaitons. Most factory wheels are HUB centric (not lug centric). If you put a 1/4 space in between, your wheel is no longer centered as the wheel will not come in contact with the hub...at all. And you can't use lug centric lug nuts on a hub centric wheel. If you do this, don't be suprised to see your wheel pass you up on the freeway.
    Lastly, like i said before, I have a 4" BS and I still rub wheen wheeling. If you want I can take a picture and show you the shiney spot.
  14. May 4, 2011 at 12:21 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I just put some 285/75/16 with 16x8 and 4.5" BS and they rub on the frame at full lock. I would get a rim with a smaller bs and you wont have any problems. Dont get spacers if you dont need to, they fuck up your angles and are hard on your parts. Just take a look at your local junkyard and find some cheap rims. Thats what im planning on doing.
  15. May 4, 2011 at 3:34 PM
    #35
    NegroTundra
    Land of Enchantment
    Yeah i had stock UCA's
  16. Aug 6, 2013 at 8:55 PM
    #36
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's exactly what I have now, and at stock height with stick wheels, it rubbed a bit on the rear side of the frame at full lock (to both sides) just on the street.
    A year ago I put 5100's on the middle setting and it hasn't rubbed since.
    Now I'm planning on 285's and going to 2.5" on the front. It might rub a bit, but like others have said, hammer the pinch weld, and you should be fine, but it still might rub during articulation.
  17. Sep 30, 2013 at 8:19 PM
    #37
    Fir3Chi3F
    Fir3Chi3F New Member
    North Ga
    04 SR5 Tacoma
    Airbox Deck plate Mod Gray Wire Mod 2.5" Daystar leveling Kit
    Just a FYI a 285/75/16 WILL NOT fit on a stock 04 Tacoma with the stock wheel and UCA without wheel spacers! I know the bush is being beat around here a little but I tried it today and it hits the stock UCA.
    Just wanted to make it clear for anyone that was not sure.
  18. Feb 2, 2016 at 6:32 PM
    #38
    Yotalife27
    Yotalife27 Well-Known Member
    Will
    Birmingham,Al
    2005 Tacoma
    3 inch lift on 285/75r 16
    What about 275's????
  19. Jan 21, 2018 at 2:21 PM
    #39
    Gunter9213
    Gunter9213 Member
    Joshua
    2012 Toyota tacoma
    4”lift
    I have a 2012 Toyota Tacoma and I have a 4”lift on it now. I bought pro comp steel wheels 16x10 that have 4”bs and -38mm offset. But I can not mount up because they hit the caliper. So any suggestions on a fix or even another steel wheel that I could get that would work with 285/75/16 mud terrain tires???
  20. Jan 27, 2018 at 11:23 AM
    #40
    BarbaricYawp
    BarbaricYawp Active Member
    Sara
    Camas Prairie, Idaho
    2010 TRD OR (Lucy) & 2001 SR5 (Zoe), both white
    MagnaFlow off-road exhaust, OME 885 lift w/ rear full Dakar leaf pack, anytime foglight mod and Contura V switch, aFe Pro-Dry S filter, color-matched grill, Yakima rack, ARE Z-Series shell, and probably more. Also have a 1996 regular cab DLX Tacoma and a 2014 DCLB Tacoma.
    I tried so many different steelie 16s on my 2010--and only the Konig Countersteers by FN worked for me (aka cleared the caliper). I run the exact same tire size as you, and I get a little rub (OME lift, so not as much clearance as it looks like you have). Follow the link. They aren't steelies, but they have held up beautifully for me, and I take my truck offroad every day.
    Good luck!
