Trying to see if the wheels i want will not harm my truck
Discussion in 'Wheels & Tires' started by Cincysean, Feb 20, 2012.
  1. Feb 20, 2012 at 8:50 AM
    Cincysean
    Cincysean [OP] Active Member
    Cincinnati Ohio
    O7 Dbl Cab Sport
    Hi all,
    I'm new to the site as well as customizing trucks but I'm finding myself getting more and more into it with my Taco ( I hear this is a sickness with us Taco owners) but i have a major question that the local dealer's service dept. seemed to be clueless about. (or too lazy to give me an answer on)
    I have a 07 Dbl Cab Sport that came with the TRD Sport Alloy Wheels: 17x7.5, 30 mm offset, 5.5" backspacing, 6x5.5" bolt pattern. They have 265 r70 17 tires on them that have 80% of the tread left.
    I'm looking to put on new wheels with the following specs: 17"x8", Offset 25mm, backspacing 5.5", bolt pattern 6-139, 26.8lbs.
    My questions/concerns are: 1. Will they work with the truck? 2. Will they work with the tires i have? 3. Will they harm anything related to the drivetrain, transmission, gears, etc. 4. Does the Sport have TPMS sensors on them and will i need to purchase the sensors from the tirerack.com site?
    Any help on this will be greatly appreciated by this newbie.
    Thanks in advance!
    Here is the link to the wheels i am looking to put on in case it helps: http://www.tirerack.com/wheels/Whee...&filterNew=All&filterWeight=All&sort=Diameter
  2. Feb 20, 2012 at 3:34 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The specs look good for the 265s. You will have to swap over your tpms sensors.
  3. Sep 19, 2012 at 8:12 AM
    skiz19
    skiz19 New Member
    Pa
    2007 TRD Sport
    I'm looking at finally doing some work to my baby, and would like to thank toyota dealers for not dealing with sub-par stock rims that are starting to severely oxidize...ahem, which motiviated me to do so.
    Will the following work with stock 265/65 R17 Duelers?
    Going from: Stock TRD Sport Alloy Wheels: 17x7.5, +1" offset, 5.5" backspacing, 6x5.5" bolt pattern, 4.25" hub bore
    To (hopefully): Racline Raptors: 17x9, 0" offset (on site), 5" backspacing, 6x5.5" bolt pattern, 4.25" hub bore
    First time dealing with this, so my concern is for caliper clearance with the .5" loss of backspacing.
    Thanks all.
  4. Sep 19, 2012 at 8:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    The "loss" of BS actually pushes the wheel out from the truck further, in your case by .5". You will be fine.
  5. Sep 19, 2012 at 6:23 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    It should be a direct swap. You can use your current tires and TPMS without any issues.
    Looking at Bridgestone's specs, it looks like your current tires are approved for a 9" wheel. You shouldn't have any caliper clearance issues. However, keep in mind that with 9" wheels, you'll probably rub a little on the plastic liner. It shouldn't be anything major, but be prepared to do a little cutting.
  6. Sep 20, 2012 at 8:10 AM
    skiz19
    skiz19 New Member
    Pa
    2007 TRD Sport
    Ok, again, newb here, ha..
    uh...plastic liner of......what? lol
  7. Sep 20, 2012 at 8:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    The inner fender is a black plastic liner
  8. Sep 29, 2012 at 11:45 AM
    skiz19
    skiz19 New Member
    Pa
    2007 TRD Sport
    At the garage awaiting install completion. Will post pics when done. Thanks for the help fellas.
  9. Nov 6, 2012 at 1:41 PM
    skiz19
    skiz19 New Member
    Pa
    2007 TRD Sport
    Sorry for the delay. I love em.
    hoangvo1992 likes this.
