TSB-0063-18 A/C issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by okccj, Aug 30, 2018.
  1. Aug 19, 2020 at 9:21 AM
    #81
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Update: My truck is now in the shop getting the TSB done. I will report back when I get it back with when the fans kick on and off.
    jerkwithkeyboard and BigWhiteTRD like this.
  2. Aug 21, 2020 at 7:40 AM
    #82
    5nahalf
    Erik
    Minnesota
    So I got my truck back last night, didnt get too much time to play with it before I went fishing.
    But there were a few things I noticed right away. AC seems a little bit better, but still not great (still banking on the fact that the ac system was overcharged) The wiring that was done was a bit iffy. The power wire going from the battery to the new fuse box has zero slack, its tight to the point that I cant even get into the normal fuse box. So tonight I am going to spend some time taking apart the truck, note the poorly done wiring (by them and all the bad wiring done by me) and fix them all at once. It feels like they glued in the left side switch panel, I cant pull it out to plug back in my bass knob.
    BigWhiteTRD likes this.
  3. Aug 21, 2020 at 3:07 PM
    #83
    5nahalf
    Erik
    Minnesota
    So I got to play around a little with my truck. I moved some of the wires around so I can get to my fuse box.
    They put a nice scratch in my bumper when they removed the grill though :( Im not even going to attempt to have them fix it though, Ill just touch up paint it and be done.
    But, overall I am happy with the repair.
  4. Aug 30, 2020 at 6:41 AM
    #84
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Mine goes in for the TSB in a couple weeks. Parts on order. It’s been hot here in CO and at stoplights my air gets a lot warmer. I have to run Max AC, Recirculate and put it in N to keep the RPM’s up at idle. I’m hoping this helps. Nobody seems to have replied with any observations post fix. My biggest concern not getting it done while under warranty is what damage the compressor etc could get with pressures going up when it can’t keep up at idle. Hoping this gives it longevity.
  5. Aug 30, 2020 at 7:37 AM
    #85
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I never experienced this. Here in the inland empire it’s been 110’f the couple of weeks. Mine is freezing cold even in traffic. Mine has the harmonic sound from the ac when acceleration but it seldom does it now compared to when it was new, can’t really complain.
    cryptolime likes this.
  6. Aug 30, 2020 at 8:13 AM
    #86
    5nahalf
    Erik
    Minnesota
    So here are my thoughts on it, my ac was perfect and great till I got my compressor replaced. after the new compressor, the ac would blow cold then warm then cold then warm. I took it in and they said it was fine and within spec. Showed them the TSB and they did it. Now it blows cold then slightly cold, then cold then slightly cold. I still have some of the same issue as before, but its better.
    My issue I think is more that they over charged my ac system, and dont want to recheck it. I had them do this TSB because I wanted to get the extra cooling fan while I could.
    Some trucks are great, some are not, its kinda random. I think it has more to do with charge pressure than the truck itself.
  7. Aug 30, 2020 at 4:43 PM
    #87
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    I had the TSB done a few months ago and it is cold now! Of course it could be because they have to recharge your system when they do this TSB and my truck had over 45k miles on it already. The service manager also had them replace a pressure sensor as well, saying that all the vehicles that needed this TSB had also needed this sensor replaced. Some Dealer’s might not be replacing that sensor.
    But I could tell an immediate difference in the cooling power of the truck after the TSB was done!
  8. Aug 30, 2020 at 6:09 PM
    #88
    5nahalf
    Erik
    Minnesota
    They dont recharge the system with the TSB, but replacing that pressure sensor would require them to recharge your system.
  9. Sep 2, 2020 at 4:29 PM
    #89
    Travis17
    Travis
    2017 Tacoma Limited
    Thanks, I didn’t know if the TSB required a recharge or not. Are other dealers doing the pressure sensor too?
  10. Sep 2, 2020 at 4:33 PM
    #90
    5nahalf
    Erik
    Minnesota
    Mine didnt do one, but its probably not a bad idea to do it when the customer had a AC issue with poor cooling.
  11. Apr 26, 2021 at 10:43 AM
    #91
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    TSB-0063-18 is now obsolete, replaced with TSB-0093-20.
    Is everyone that had this TSB performed happy that they did it?
  12. Apr 26, 2021 at 11:01 AM
    #92
    5nahalf
    Erik
    Minnesota
    So I just went through both TSBs to find what they changed... looks like the only thing changed is they removed 2 pages detailing how to modify the fan to fit (cutting off mounting tabs)
    The fans have the same part number still, so not sure if they are just mounting the fans with the extra tabs sticking out.
    I was not happy with how they wired it, so I redid some of the wiring myself. Otherwise it works as it should.
    Tacompa[QUOTED] likes this.
  13. Apr 26, 2021 at 2:07 PM
    #93
    Tacompa
    San Jose, CA
    My dealer is saying that they can't perform this TSB on my truck since they can't replicate the failure. That's because the high in San Jose today is 62. Any suggestions on how to get the dealer to do this?
  14. Apr 26, 2021 at 2:12 PM
    #94
    5nahalf
    Erik
    Minnesota
    Cite the first 2 lines from the TSB repair procedure
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10181775-9999.pdf
    Page 4
  15. Apr 27, 2021 at 10:08 AM
    #95
    Tacompa
    San Jose, CA
    @5nahalf worked like a charm!! Thanks for the suggestion. My dealer is ordering the parts and will let me know when they come in.
    Spike Strip and 5nahalf like this.
  16. Apr 27, 2021 at 10:20 AM
    #96
    5nahalf
    Erik
    Minnesota
    Glad you got it sorted out. When they are all done, give the wiring they install a good look over, you may need to re-route some of them as they put them in a bit tight.
  17. May 25, 2021 at 8:12 PM
    #97
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
  18. Jun 1, 2022 at 7:18 AM
    #98
    ToyoTX85
    ToyoTX85 Well-Known Member
    Sorry to revive this post but wonder if more people have done this TSB , I notice yesterday this a bit when idle at 100 F yesterday on central TX
    mine is a 2020 SR5 and is about to be out of the 36 months warranty but also scared they mess up the taking the dash since is so intrusive this TSB
  19. Aug 26, 2022 at 2:11 PM
    #99
    Pagan Taco
    Pagan Taco New Member
    2018 TRD Sport
    Here you got the whole document
  20. Mar 5, 2023 at 1:49 PM
    #100
    Spike Strip
    Spike Strip Well-Known Member
    2023 TRD OR DCSB
    Anyone notice this issue on 2022/23 models? I know,'23s haven't seen a summer yet, but asking...
