Tsb 08 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REVHARD25, Aug 21, 2008.
  1. Aug 21, 2008 at 6:44 PM
    REVHARD25
    REVHARD25 [OP] Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    So i went to the stealer ship today to try my luck with the leaf spring tsb. i told the service idiot that the truck sags and bottoms out with 500 pounds in it. He says there is no tsb for 08 prerunner and they will make an appointment to have it looked at. He kept saying its not a recall so there is not much we can do unless there is a legit reason.
    what do you guys think?
  2. Aug 21, 2008 at 6:49 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    make him aware that u have the same suspension as the 05-07's that have the tsb listed for them
  3. Aug 21, 2008 at 6:49 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    bull shit.
  4. Aug 21, 2008 at 7:13 PM
    WildcatRider
    WildcatRider Well-Known Member
    Lexington, KY
    2008 AC TRD-OR 4x4 SOLD
    Check the part numbers on your springs.. if they end in -G then you don't need the TSB.
    Some 08s still have the -F revision so I guess there would be a legit complaint there... I loaded about 700lbs in my bed and my friend and I were jumping up and down in it as hard as we could and it wouldn't hit the bump stops... I have an 08 with the -G revision rear springs
  5. Aug 21, 2008 at 7:22 PM
    REVHARD25
    so cal
    i told the service guy this. i told him the part #s are the same as the 05-07 with the f on the end. He said well there is no tsb in the system for the 08 so all we can do is look at it
  6. Aug 21, 2008 at 8:57 PM
    wawireguy
    wawireguy Well-Known Member
    Tell him there are a bunch of us and we are gonna sue Toyota. If anyone decides to class action them let me know. I'm not overly happy with them.
  7. Aug 21, 2008 at 8:58 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Tell them if they won't do the TSB, You'll find another dealer that will and you will take your business there instead.
  8. Aug 21, 2008 at 9:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may have to call the 800 number and get a case set up......who knows, they may call your dealer with the tsb go ahead the next day.
  9. Aug 21, 2008 at 9:24 PM
    REVHARD25
    so cal
    Thanks guys for the help. i was almost dumb founded at what an a hole the service guy was. Like i was ripping him off or somthing. I just want a good quality truck and if there is a prob with these leaf springs then i def want them done right
  10. Aug 21, 2008 at 9:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you are in the right...they just like being jackasses!!
  11. Aug 21, 2008 at 9:56 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    not to jump in with Questions, but will all 07's with a G need to be replaced?
  12. Aug 22, 2008 at 11:44 AM
    Fish Tacos
    Fish Tacos Active Member
    Conn
    2009 Double Cab TRD Off-Road
    I am a rookie tacoma owner (48 hours) and am SOO pumped about my new ride but can someone explain exactly what is a TSB? I assume it's a manufacturers recall or repair free of charge - is that it....? Thanks.
  13. Aug 22, 2008 at 11:47 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    I haven't tried to look, but where would the part number be located on the spring?
  14. Aug 22, 2008 at 11:49 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    put 500lbs of sand in the back. Show them that it bottoms out. You will have no problem getting the work done if you can display it to them.
  15. Aug 22, 2008 at 11:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The TSB is a Technical Service Bulletin- It's a resolution for a hard to diagnose or identify problem. In this case it relates to a harsh ride (bottoming out) with a light load in the bed. If your truck qualifies by either a) being on the TSB and/or b) demonstrating the problem to a service center it should be done fre of charge (if you are within warrantee)
    Yes
  16. Aug 22, 2008 at 11:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You are in the right- If your springs are the old parts....The service center won't want to give up the labor time to a warrantee job- so they might not make it easy.
    As soon as you make the call to Customer Experience- You should get worked out...
  17. Aug 22, 2008 at 11:54 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there should be a white sticker on the top of the spring............and it will have the numbers on it.
  18. Aug 22, 2008 at 12:02 PM
    klown
    Lynchburg, VA
    Honestly, this is the first I've heard of this problem on an '08 access cab. The only ones I've heard having this problem on 2008's are the DC longbed. Toyota supposedly fixed this problem.
    Just buy sand bags from homedepot. Then show the service manager that it's bottoming out. Then go return the sandbags back to home depot.
    You can argue all you want with the corporate guys and the service manager, bottom line is...they aint gonna do shit until you can display to them the problem.
  19. Aug 22, 2008 at 12:17 PM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    i just called toyota to get mine done. they said they are researching it and will call me back. keep your fingers crossed for me
  20. Aug 22, 2008 at 12:41 PM
    klown
    Lynchburg, VA
    ^^^^^^^^^^^Yours should be covered by the TSB though? You may still have to display a problem to the jerkoffs.
