tsb aal help
Discussion in 'Suspension' started by skidynastar33, Nov 28, 2009.
  1. Nov 28, 2009 at 9:03 AM
    skidynastar33
    skidynastar33 [OP] Active Member
    kyle
    seattle
    09 taco
    trying to install the tsb aal with the tsb done
    just going to put it on and noticed i didnt get new u bolts, so do the u bolt put on during the tsb going to be long enough? it looks pretty close.
    does anyone have any pics of it done?
  2. Nov 28, 2009 at 10:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The U bolts that were installed with the TSB springs should be long enough. You should have about 1/4" thread showing after the AAL install. If not, the dealer may not have installed the new U bolts.
  3. Feb 9, 2010 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is what correct? My reply?
  4. Feb 9, 2010 at 8:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  5. Feb 25, 2010 at 7:13 PM
    PaulVthe3
    PaulVthe3 Well-Known Member
    Hey I have a fabtech AAL, can I add it to a set of tsb springs? Ive got 5100s up front set at 2.5 and the AAL in the rear and Im tired of seeing the sag. So I want to drop my 5100's to stock take the AAl out and get the TSB springs for my 09 dc 4x4. Then once I get it back I want to put the 5100's back to 2.5 and throw the AAl on the tsb springs. Is it possible? I do have 5100's in the rear as well.
  6. Mar 27, 2010 at 7:39 PM
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    :notsure: same question.....TSB and AAL???????????
  7. Mar 27, 2010 at 10:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. A short AAL, or the 1.5" one from Toytec will fit the TSB springs.
  8. Apr 8, 2010 at 11:50 AM
    twr437
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    Will this AAL make the ride way to stiff??
