TSB for my 08 Taco TRD
Discussion in 'Suspension' started by Brunes, Jun 1, 2008.
  1. Jun 1, 2008 at 8:51 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    I've got the TRD package with the Billie shock kit. I've read up on the TSB and when I get home- I'm looking at my truck and then going to talk to the dealership about it.
    Over the course of reading the forum- I caught some stuff about leveling and about the 5100 series shocks.
    My question is this- Can I level out the truck without going to aftermarket parts?? How about after I do the TSB??
    Just trying to make sure I've got my info straight before I go off ordering parts and stuff.
    Thanks guys!!
  2. Jun 1, 2008 at 10:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You will need to lift your front end by about 2" or so to get the truck level. Its a piece of cake to do! :)
  3. Jun 1, 2008 at 3:23 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    ::nods:: That's what I thought-
    So I'm in for a 90 dollar (or so) leveling spacer set, and 2XX bucks for the 5100 shocks in the front?? And I guess it's worth the upgrade to the 5100's in the back too??
  4. Jun 1, 2008 at 3:30 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Screw the spacers, just get the 5100s if you want it level.
    For just the fronts its $160 shipped through down south motorsports on ebay.
    You can keep running the factory bilstiens in the rear if you want.
  5. Jun 1, 2008 at 9:43 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    So the stock springs will be long enuf with the 5100s??
  6. Jun 2, 2008 at 3:59 AM
    Khaos
    Khaos Big Member
    Bryant
    Yes the stock Coils are what your supposed to use with the 5100s.
    Both Bilstien and Toytec say not to use the 5100s with a spacer lift but to use them with the stock coils.
  7. Jun 2, 2008 at 4:21 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    Nice....Appreciate the info!!
    Apparently the leaf pack was "fixed" for '08...So i'm going to have to load up the truck and see what happens.
    Any other 08' owners had the problem??
  8. Jun 10, 2008 at 10:14 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Don't know about fixed? I never actually hauled anything real heavy with the 3 leafs that came on the truck origionally. I had the TSB done adding the 4 leaf springs and have since hauled some pretty good weight. I like the way it handles both with a load and without. Don't feel the dealer would have done it to my '08 if it has truley been fixed by beefed up 3 leafs. With the stock TRD shocks my truck was about 2.25" higher in the rear after the TSB.
    I added 5100's all around and adjusted the front 5100's to the .85" setting and the rear is still 1.25" higher in the rear, which I like. Set this way with a load it is still level or slightly taller in the rear. Set to the third setting of 1.75 would probably have set my truck exactly level running light. Note that everybody gets different results with the TSB.
