TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Dec 30, 2010 at 2:02 PM
    #301
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    somewhat. They get really specific about making sure that you know a TSB and a recall are not the same words.
    TSB is pretty much how dexterdog described, although it is under-warranty work and it is typically a non-safety issue. You can waive the TSB and the service desk can skip it if you don't meet the preconditions (which it's just easier for them to do the work anyway)
    Recall is work that needs to be performed that addresses critical safety issues that does not require a precondition. The service department pretty much has to do it whether you want it done or not
    A voluntary recall is a recall that you can waive.
    Sometimes a voluntary recall and a TSB is a bundled deal. For instance I couldn't get the shift point reflash TSB if I didn't agree to the shaved pedal.
  2. Jan 4, 2011 at 1:25 PM
    #302
    whitetacoma1
    whitetacoma1 White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
    i had my blower motor replaced and need it replaced again as it is squeaking again. this will be the second in 6 months
  3. Jan 4, 2011 at 7:51 PM
    #303
    Chickenmunga
    Keizer, Oregon
    I just went in for the same. They have "negative two" on inventory for the united states
  4. Jan 7, 2011 at 12:52 AM
    #304
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    tried searching for steering column tsb and didn't find anything. Is there a TSB for the steering column rattle? I went on the gravel road for the first time and my steering wheel felt like it was loose...
  5. Jan 7, 2011 at 7:40 AM
    #305
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Here you go.
    http://www.scribd.com/doc/30915037/T-SB-0119-10
  6. Jan 8, 2011 at 12:09 AM
    #306
    ruslanus
    Rus
    Wasilla, AK
    That's the one, thank you. Will be going in for the scheduled maintenance soon and will mention my steering column rattle to them along with the transmission TSB. We'll see what good comes out of it... Took a while to persuade them to do the Rear Leaf Spring TSB, might take some more tug of war
  7. Jan 8, 2011 at 8:34 PM
    #307
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    I have a 07 dc 4x4 I had the original springs replaced under the tsb they were fine for a while now these are doing the same thing. Under a load it bottoms out easily.
    I think the replacement spring is the exact same crap as the originals. I haul alot of stuff and going to look into some different spring options at a spring shop.
  8. Jan 12, 2011 at 9:55 PM
    #308
    707_ent
    707_ent New Member
    Eureka, CA
    05 Double Cab Long bed TRD Sport 4x4
    OME front springs and struts, OME Dakar rear 3'' springs, Amsoil Bypass filtration kit, PIAA Xteme White bulbs, JVC In-Dash DVD player, Pro Comp 6047 17 x 8.5, BFG KM2's
    I have an 05 DC LB and my mechanic just notified me of a crack on the frame where the motor mount meets the frame. He says its a common problem on the 05's but only in the first half of the production year. He said toyota fixed the problem halfway through that year. Well at least he caught it when he did because otherwise it would have cracked the frame completely making it a complete piece of junk (unfixable). It entails the motor to be removed and the motor mount to be rewelded, a $1200+ job.:frusty: :rolleyes:
  9. Jan 13, 2011 at 6:21 AM
    #309
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    which mount was it? i want to know what i am looking for when i crawl under there.
  10. Jan 17, 2011 at 7:14 PM
    #310
    707_ent
    707_ent New Member
    Eureka, CA
    The passenger side motor mount.
  11. Jan 18, 2011 at 4:41 AM
    #311
    comiesutra
    Greenwood, IN
    thank you
  12. Jan 20, 2011 at 11:48 AM
    #312
    army5102
    army5102 New Member
    2010 full 4 door short bed
    does the tsb for the shocks apply to 2010 models
  13. Jan 21, 2011 at 4:24 PM
    #313
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yes. That is the same answer I gave you in the thread you started. No one else answered I'm sure due to the amount of posts on this subject. The search function is your friend.
  14. Jan 22, 2011 at 8:14 AM
    #314
    707_ent
    707_ent New Member
    Eureka, CA
    Actually it may be either side, but mine was only on the passenger side, so look at both.
  15. Jan 22, 2011 at 12:54 PM
    #315
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Will TSB fixes be performed if a problem is found on a vehicle under 36k mileage, but older than 36 months? (05)
    I do have an extended warranty.
  16. Jan 23, 2011 at 12:50 PM
    #316
    06silverbullet
    06silverbullet Active Member
    Salem, SC
    2011 Sport DC 4X4
    3" Toytec w/ AAL's. GT Covers seat covers, Weathertech floorliners, 3M tint, Century Ultrasport cap w/ Yakima load warrior basket.
    Anybody heard of a TSB on hte front wheel bearings? Just replaced both of mine. 80,003 miles and they were both shot. No mud or nothing. 8 Toyotas in my life and never had a wheel bearing issue!
  17. Jan 23, 2011 at 1:02 PM
    #317
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    06,
    got pics? Would love to see their condition...
  18. Feb 1, 2011 at 8:44 PM
    #318
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Thanks for the list. I will be looking into this.
  19. Feb 2, 2011 at 6:31 AM
    #319
    TheWrongWay
    TheWrongWay Active Member
    Jacksonville, FL
    White '08, 4x4, V6, Auto DoubleCab T
    3" Lift from RevTech, USA Spec Ipod Interface
    I took my '08 TRD Sport Tacoma in this morning for the TSB at Arlington Toyota in Jacksonville, FL. I mentioned that I have the 3" front, 1-1/4" Revtek Lift Kit installed and he said it wouldn't be a problem as long as they can determine there's an issue with the leaf springs. I will be sure to post an update when I hear back.
  20. Feb 2, 2011 at 11:21 AM
    #320
    TheWrongWay
    Jacksonville, FL
    So they said it was a no go. They told me I would need to take off the lift kit and return my truck to stock before they would do any work. I also looking into OEM TSB leafsprings and they are $699 a piece plus labor. Sounds like I might just buy an add-a-leaf from Revtek, some Bilstein 5100's and call it a day.
